03-14-2013, 02:58 AM   #1
Converters on Sigma 70-200 HSM II?
I'm seeking comments from anyone who has found a good quality teleconverter to marry to the Sigma 70-200mm F2.8 EX DG APO Macro HSM II. Thanks in advance.
03-14-2013, 03:59 AM   #2
I use the Pentax 1.7x AFA - it is the only one which will work for the Pentax mount.
03-14-2013, 05:11 AM   #3
Banned
QuoteOriginally posted by bhairavp Quote
Not exactly. Sigma also currently markets two teleconverters that will work with most any Pentax digital slr
03-14-2013, 07:16 AM   #4
Not sure that works with Pentax - Sigma has not launched any HSM-compatible TCs for the K Mount
03-14-2013, 11:38 PM   #5
ditto, but it doesn't report the correct F ratio but still exposes OK.
bb2
03-15-2013, 02:29 AM   #6
^Pins 1 and 4 on the lens side of the adapter should be taped, you'll get the correct F number in EXIF.
03-15-2013, 02:52 AM   #7
If I could ask some clarifying questions of the Pentax 1.7x: -
- Is the lens AF speed and accuracy maintained?
- How much image sharpness is lost through teleconversion?
I'm not after explicit details, just a general opinion from first hand experience.
Thanks in advance.
03-15-2013, 03:51 AM   #8
^You have to manually prefocus to the general vicinity of the subject, and then the AFA takes over to lock on. Generally decently accurate.
I've only taken a few shots with my Sigma so far, but it seems to be quite sharp, even wide open. It doesn't make sense using it with slower lenses, as the 1.7x reduction in f-stop makes for difficult AF locks.
03-15-2013, 04:13 AM   #9
Ash
Ash's Avatar
I have had personal experience with the Tamron 1.4x Pz-AF, which is SDM compatible, with the Sigma 70-200 II and it was unable to fix focus at focal lengths from about 160-200mm, even in full sunlight. So the focal range where you would really want it to perform, it failed to do so with this TC. I gave up with the Sigma and went with the screwdriven Tamron 70-200 which works perfectly with the aforementioned TC.
03-15-2013, 04:18 AM   #10
Thanks for that. Does report correct F ratio on rear LCD, although not on the top window. Dark here now so need to do testing tomorrow in bright light.
I think the combo of lens plus TC needs to be stopped down a couple of stops to get rid of some flare. Nett result is sharp so TC is useful. AF is usually very fast with the Pentax 1.7 AF TC.
bb2
03-15-2013, 04:39 AM   #11
bhairavp - that's what I needed to know. Thanks.
03-15-2013, 04:57 AM   #12
QuoteOriginally posted by beachboy2 Quote
bb2
Use the hood.. it makes a difference. Very little flare here.
Ash- exactly, the AFA 1.7x is the only "TC" that will work correctly with the 70-200 HSM II on Pentax.
03-15-2013, 08:13 PM   #13
bb2
Whoops! So covering the pins gets correct aperture recorded but AF is lost. So think I'll stick to incorrect aperture and super fast AF.
cheers
bb2
06-10-2013, 07:41 AM   #14
cheers
bb2
Has anyone posted sample photos or a YouTube video of the 70-200 hsm II functioning with a teleconverter? If you know of any, could you please post a link? If not, and anyone has this combo, a sample photo or video would be much appreciated!
Thanks
Mikal
06-10-2013, 10:38 AM   #15
I shot these last friday, first time with my Pentax AF1.7 - Sigma 70-200 HSM combo. it worked fine for me. Sharp enough and easy to focus. I have not tried taping the contacts to get the proper f-stop values yet.
hsm, k-mount, pentax lens, sigma, slr lens
Wanted - Acquired: Sigma 70-200 DG HSM or HSM II wtomlin76 Sold Items 7 02-04-2013 02:40 PM
Focus on Sigma 70-200 F2.8 HSM II BravoMike Pentax SLR Lens Discussion 12 12-24-2012 08:40 AM
For Sale - Sold: Sigma 70-200 f/2.8 HSM Macro II Isnwm Sold Items 7 09-21-2012 03:25 AM
Sigma 70-200 2.8 HSM II vs OS PhilV Pentax K-5 & K-5 II 10 06-30-2012 04:31 AM
Sigma 70-200 HSM II vs. 70-200 HSM II OS Mehlsack Pentax SLR Lens Discussion 4 02-19-2011 10:05 AM
All times are GMT -7. The time now is 02:37 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
