03-01-2008, 07:53 PM   #1
Anyone use Fujica M42 mount lenses
Anyone use these gems on their Pentax K mount??
There are 2 problems with the EBC versions of the lenses
There is no auto/manual on the stop down and there is a metering tab on the lens flange.
On my Canon 5D I had adapters that would push the pin in to stop it down.
I had to deal with the tab on the lens by not being able to screw it in all the way. I thought about grinding the tabs off the lenses, but ended up selling the canon.
Now all of the pentax adapters I have seen do not have a tab to push the pin and stop the lens down...
So is this a lost cause now?
03-01-2008, 08:11 PM   #2
I have the same problem with one of my Soligor 250mm M42 mount... You could try trimming the tab down a little bit so that when it's pushed in to stop the lens down, it sits flush with the lens itself, and then you could simply glue a tab over it to lock it down.
03-02-2008, 10:53 AM   #3
I glued a disc onto the bottom of one of my M42 adapters and this works fine.
All you need to do is get a disc machined at the right size...(mine came from a forum member who had an extra)
03-08-2008, 06:45 PM   #4
I am surprised they do not make a machined adapter with the disk machined on.
They have this for Canon
03-09-2008, 01:00 AM   #5
ryan s's Avatar
You're right, I was expecting a Pentax solution to this as well. The Fuji was a PITA to use because of the metering tab.
Guess you can't win em all...Pentax only guarantees their lenses to work :/
adapters, canon, k-mount, lens, lenses, pentax, pentax lens, pin, slr lens, stop, tab
Fujica Bayonet mount camera question winglik Pentax Film SLR Discussion 5 02-19-2009 12:54 PM
M42 mount lenses..... Aaron1971 Pentax SLR Lens Discussion 13 11-05-2008 07:14 PM
How to use Fujica M42 lens on Pentax DSLR vanchaz2002 Pentax DSLR Discussion 16 06-02-2008 07:56 PM
All times are GMT -7. The time now is 01:49 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
