03-26-2013, 04:16 PM   #1
croping or tammron 1.4 teleconverter
I have pentax k5. if the pexils go from 16 to 12, when the picture is crop, is this the size of picture with 1.4 teleconverter attached?
03-26-2013, 04:25 PM   #2
manacho2005's Avatar
By the math, the TC has 7% less field of view (more zoom) than a 16->12 MP crop
But you lose a little light with the TC.....
03-26-2013, 04:43 PM   #3
Moderator PEG Judges
Kerrowdown's Avatar
QuoteOriginally posted by manacho2005 Quote
Also possibly some IQ as well as a result of the TC.
03-26-2013, 09:06 PM   #4
dms
A 1.4 teleconverter reduces linear dimension by 1.4, and thus on area basis reduces by about factor 2 (1.4x1.4). If you crop to get the same result you will reduce the pixels by factor of 2. It is (IMO) always better to use a teleconverter rather than cropping--if the teleconverter and the lens are good. (Most teleconverters I have tried are good, and if the lens is a pentax prime it also is likely good. BTW for macro work teleconverters are generally excellent.) And If the lens is not very good either way it will not be good. BTW many people would not agree with me on this. Best to try a test.
03-26-2013, 09:21 PM   #5
MegaPower's Avatar
both tamron 1.4x and kenko 1.5x are very teleconvertor.
They are better then cropping.
03-26-2013, 09:45 PM   #6
dms
Before I am tared and feathered--perhaps I should say a bit more about "it is always better to use a TC IMO." I mean if the lens is in both cases at an optimum setting and shutter speed, etc. are fine. If the TC forces you to use the lens wide open, or at too low a shutter speed then it is not advantageous. And if there is a lot of glare adding a number of additional glass surfaces may be problematic. And a TC is not as convenient! But under optimal conditions the TC is better than cropping.
k-mount, pentax lens, picture, slr lens, teleconverter
telemacro tammron 500mm 1:8 Tromboneking Pentax SLR Lens Discussion 7 03-04-2012 07:29 AM
cheap 1.4x or 1.5x teleconverter in fd or md mount? ripit Pentax SLR Lens Discussion 4 02-02-2012 02:00 PM
Wanted - Acquired: Pentax A, F, or FA 50 mm (1.4 or 1.7) reivax Sold Items 4 08-01-2011 08:36 AM
All times are GMT -7. The time now is 12:25 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
