Originally posted by Driline Your close up picture of the DA 15 is impressive. Had you not labeled it a DA 15, I would have guessed it to be one of the three limited FA lenses.
yes, the DA15mm f/4 ED ASPH does have its virtues, its optical design is clearly of pentax heritage. The upper left corner of that image you can see a hint of a 7 bladed aperture - the FA limited lenses have 9 blades, the 7 bladed aperture is part of the optical signature of the DA15. My issue with the DA 15 is that even at f/8 it isn't as sharp in the corners as my Sigma 8-16mm f/4.5-5.6 is @ 15mm - also the sigma zoom has lower chromatic aberration than the DA15, this can be corrected in post production however the loss of sharpness in the corners cannot be corrected. The DA15mm f/4 also has some pretty bad field curvature which makes manually focusing it a bit of a challenge - the slow f/4 aperture doesn't help with that either.
But if you are aware of these quirks, the DA15mm f/4 is a real joy to work with:
Pentax K10D - Pentax DA15mm f/4 ED ASPH Limited
