Show Printable Version 4 Likes Search this Thread
03-26-2013, 08:13 PM   #1
troika's Avatar
F50 1.7 Hood?
I have an in-bound F50 1.7, which I'm looking forward to. I've read that it doesn't need a hood because the element is recessed and I can see from pictures that it is compared to the 1.4 versions or either of the FA 50s. I've also seem some threads about which hoods people were using for these lenses without mention of the recessed element or the need for one.
Does anyone who has owned this lens have a strong opinion about whether it does or does not benefit from a hood of some kind?
03-26-2013, 08:24 PM   #2
I still think it would benefit from a hood. You can get a nice rubber one on ebay (some even exist specifically for this lens, I believe).
03-26-2013, 08:27 PM   #3
GabrielFFontes's Avatar
Well, yeah, it does benefit from a hood, but not a LOOOT.
You could use a 135mm lens hood for this one.
03-26-2013, 08:44 PM   #4
troika's Avatar
Thanks, guys.
03-26-2013, 09:24 PM   #5
I'd heard you could use a 49->28mm step down ring as an inverse hood with marvelous results. This is assuming it will function the same as the K/M/A/F/FA 1.4s. I'd say one could even attach a threaded hood, then apply the inverse hood in the inner of that one to provide "Maximum Coverage"
03-26-2013, 09:27 PM   #6
troika's Avatar
I read that thread, but the photos were dead links, so I couldn't see what it looked like.
03-26-2013, 09:46 PM   #7
QuoteOriginally posted by Eulogy Quote
Turns out that the 49-28mm step down ring just works as an aperture ring, reducing the effective f-stop of the lens, meaning you could just stop down this lens.
This would happen because this F 50mm 1.7, for example, is pretty sharp at f2, but soft at f1.7...it would reduce the f-stop slightly (to close to f2, probably) and make the lens "sharper", but you lose light.
It would still be a bit better, since you would have a rounded aperture at f2, instead of having it looking weird like it would if you stopped down.
03-26-2013, 10:12 PM   #8
reeftool's Avatar
All lenses can benefit from a hood. The rubber ones do the job and don't cost much.
03-27-2013, 12:01 AM   #9
EarlVonTapia's Avatar
Rubber hoods get warped pretty easy when they're sitting in your camera bag (they might even arrive all warped!) and then they look like cheap junk dangling on the tip of your package.
If you insist on using a hood with it, just take off the rubber from the cheap hood and you're left with a solid ring that is slightly thicker than your typical filter ring. Stack another ring on top of this (either a filter with the glass popped out, or a step-up ring) and now you have a solid, immovable, elegant "hood" for your lens.
One day, I'm going to fuse my F 50 1.7 with my heart. Like Iron Man.
03-27-2013, 12:35 AM   #10
troika's Avatar
QuoteOriginally posted by EarlVonTapia Quote
...cheap junk dangling on the tip of your package.
Yikes! I definitely don't want that.
03-27-2013, 01:14 AM   #11
QuoteOriginally posted by troika Quote
What?
03-27-2013, 02:41 AM   #12
PEG Moderator
Kerrowdown's Avatar
IMHO all lenses benefit from a hood, for protection if nothing else and usually contrast gets a boost too.
03-27-2013, 02:46 AM   #13
Mattco26's Avatar
Or you could jusy buy a 49mm metal hood from ebay for 3 or 4 dollars. They work great. I don't understand why so many people use the crappy rubber ones.
03-27-2013, 03:36 AM   #14
macTak's Avatar
I use the Takumar 135/3.5 hood (which has a 49mm thread, as does the F50/1.7). It's a nice, sturdy, deep hood, and has the benefit that at 62mm lens cap will secure on the front of it, so you never have to bother about taking the hood off.
03-27-2013, 04:58 AM   #15
bdery's Avatar
I've tested f1,7s and f1,4 together, and while a hood is never a bad thin, the f1,7 does not "need" one. The improvement in contrast was very hard to spot with the hood on, contrary to an f1,4 where it does make a world of difference. It's a matter of preference, for me a hood is cumbersome and the gain was not visible, so I don't use one.
QuoteOriginally posted by Mattco26 Quote
Because they collapse and are easier to carry.
element, f50, hood, k-mount, pentax lens, slr lens
For Sale - Sold: $25 lenses: K1000, A50 1.7, M50 1:2, Super Takumar 55 2, etc sergysergy Sold Items 60 05-02-2013 11:38 AM
Lens hood for f50 1.7 and f35-70 karelson Pentax SLR Lens Discussion 10 05-24-2012 01:17 PM
f50- 1.7 question COULDBE2 Pentax SLR Lens Discussion 2 05-07-2012 10:09 AM
For Sale - Sold: K20d, da18-135wr, F50/1.7 apisto Sold Items 5 01-24-2012 09:29 AM
Damaged Filter Ring ON F50/1.7 violini Pentax SLR Lens Discussion 7 08-30-2011 07:38 PM
All times are GMT -7. The time now is 10:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
