03-03-2008, 06:07 AM   #1
rparmar's Avatar
enlarger lens know-how
Way back when there were some tantalising posts on using darkroom lenses like Schneider Componon-S and Rodenstock Rodagon as macro lenses. Can anyone tell me:
* do these get coupled on front of a normal lens or used as-is?
* what mounts are required?
* will they require stop-down metering?
* do they benefit further from extension tubes?
* does this solution provide any benefits over getting an older 100mm macro and adding tubes?
Thanks for any help!
03-03-2008, 06:28 AM   #2
Lowell Goudge's Avatar
I would think these need a bellows for use.
To be honest, I never thought about it because I sold all of mine years ago
03-03-2008, 08:52 PM   #3
QuoteOriginally posted by rparmar Quote
1) You would need a bellows or extension tubes with a focusing rail
2) You would use stopped-down manual metering (P, AV, or Manual) since the aperture will be manual or pre-set at best
3) The mount is M39 (Leica thread), though I think adapters are available (M39 --> M42--> K-mount ???)
03-04-2008, 05:18 AM   #4
rparmar's Avatar
OK thanks! That's maybe too much for me to take on at the moment. Looking for a cheap way to get into macro but want the ratio to be 2x or better without sacrificing quality. Don't mind extension tubes but not likely to buy rails and bellows etc. Would also prefer a method that preserves auto-aperture (though manual focusing is of course a necessity).
03-04-2008, 05:46 AM   #5
JCSullivan's Avatar
It would look like this - it is still taking-up space in one of my cases.
03-04-2008, 11:02 AM   #6
rparmar's Avatar
QuoteOriginally posted by JCSullivan Quote
Thanks for the pix... that helps me get a feel for the setup.
How did it work out for you? Did you replace it with another macro solution or move on to other fun stuff?
I just went around the room using a second lens as a cheapo reversing solution. I couldn't get focus or steady myself enough but had good fun anyway. I think this could be addictive!
03-05-2008, 08:24 AM   #7
JCSullivan's Avatar
Yes, macro can be addictive. I didn't have much success with the bellows for a couple of reasons. One being that to fucus you need to move the camera and the bellows.
03-05-2008, 08:50 AM   #8
I have thought from time to time also about a bellows, but to really make a go of it, you need a rack and pinion attachment between bellows and tripod for fine adjustment.
In fact, you really also need this for even a regular macro lens beyond true 1:1.
When I looked at copying old photos years ago, I built a specific copy stand out of an old enlarger so I could get the camera square to the paper, and to adjust easily the height above the photo for framing.
Usually I would mount the photo into an enlarging easel to hold it flat.
I have, since that time gotten rid of my darkroom and all that stuff, and use a flat bed scanner now.
enlarger lens, k-mount, lens, lenses, macro, pentax lens, slr lens, tubes
Help ID My Enlarger akfreak Film Processing, Scanning, and Darkroom 20 08-22-2010 02:02 PM
Durst F30 24x36mm enlarger? NecroticSoldier Film Processing, Scanning, and Darkroom 14 08-04-2010 10:26 AM
buying a used enlarger; how to transport it? jzietman Digital Processing, Software, and Printing 23 05-14-2010 12:31 PM
Bogen 22A Special enlarger... Anyone know about them? pentaxbling Digital Processing, Software, and Printing 8 09-30-2009 09:38 PM
Film Processor with enlarger and paper ? HarryN Pentax Film SLR Discussion 10 03-29-2009 07:19 AM
All times are GMT -7. The time now is 02:18 PM. | See also: NikonForums.com, part of our network of photo forums!
