03-28-2013, 08:22 PM   #1
da 15 fell to ground with tripod
Got my camera with da15 mounted on the tripod and fell to the ground. I just cannot pull out or push the hood in smoothly. I think the focus ring is not perfectly rounded. Any idea to fix it?
thanks
03-28-2013, 10:02 PM   #2
You may want to post some pictures.
03-29-2013, 12:36 AM   #3
Erm.... It sounds really bad enough..
How else can anyone here advise you other than to send it in at your expense or warranty?
03-29-2013, 12:53 AM   #4
wlachan's Avatar
Don't force anything. The distorted parts have to be replaced.
03-29-2013, 01:38 AM   #5
jkomp316's Avatar
QuoteOriginally posted by yjcs Quote
thanks
its junk, sell it to me for $100
03-29-2013, 05:29 AM   #6
Moderator PEG Judges
Kerrowdown's Avatar
Oh dear, that's not sounding too good, I think it's time to visit the repair centre.
03-29-2013, 07:47 AM   #7
Just use a little force and it will work just fine.
Or send it in to be repaired
03-30-2013, 09:01 PM   #8
thanks all for the reply. I can see that the gap between the hood and the focus ring is different in different direction. I can genteelly pull the hood out and bend it to a special angle the I can move the focus ring relatively easier. I think I can at least manual focus. I love this lens though.
03-31-2013, 11:38 AM   #9
MSM
MSM's Avatar
Unfortunately I have a lot of experience in this matter. When traveling to Walt Disney World, I dropped my camera with a DA 15 attached within the first 45 sec of entering the Magic Kingdom. That has to be a record! I knew someone in my family was gonna cry at some point in the day. I just didn't think it would be me.
Anyway I always extend the hood. Thank goodness. It saved my lens. I bent the hood badly. Like you. I could not retract it. The lens was otherwise perfect in appearance. The focus ring was also jammed due to the hood. I slowly worked the hood out to a full extension that allowed the focus ring to travel normally. But I also know that it could now be pulled out just a bit further which tightened up the focus ring again. After getting home, I CAREFULLY took some cloth to cover the bent part of the hood and then using a needle nose plyers reshaped the hood. I took a long time working with the metal. It is possible to mold it so that it slides smoothly. Don't expect miracles. In the end, the hood worked well and the AF and MF. I hope this helps. Worse case is send it in. In my case fixing the hood solved everything. Note I didnt see how bad your damage was. I just know tha the force of the impact distorts the hood that interferes with the focus ring.
Mark
04-01-2013, 08:17 AM   #10
I have you beaten. Couple of years ago I bought a Fuji exr 200 for ~ 500$ the day before leaving for a trip in Cuba. Took a coupe of pictures in the plane on the way there, left it on the plane, under the seat... Never got it back.
QuoteOriginally posted by MSM Quote
Mark
ground, k-mount, pentax lens, slr lens, tripod
DA 15 and DA 12-24 with DXO Optics Pro seadog Pentax SLR Lens Discussion 9 04-15-2013 03:09 AM
DA 15 Ltd or just stick with 18-135WR? SpartanD63 Pentax SLR Lens Discussion 15 11-25-2012 11:22 AM
the venerable DA 15, possible to do close up portrait with bokeh? lightbulb Pentax SLR Lens Discussion 15 03-12-2012 09:13 AM
For Sale - Sold: K7, DA 16-45, DFA 100 2.8 WR macro, DA 15 Ltd, Cullmann tripod, other small st Cristian Sold Items 12 10-30-2011 11:32 AM
For Sale - Sold: DA 15, DA 40, DA 70, DA 16-45, DA L 55-300, AF360 (Worldwide) yoshizuki Sold Items 23 10-22-2011 03:24 PM
All times are GMT -7. The time now is 06:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
