04-01-2013, 10:12 AM   #1
Angle of view question
Is the lens' angle of view measured from the sensor or from the front element of the lens?
I.e. the front element of the DA 16-45 mm @ 21 mm is probably ~125 mm away from the sensor while the DA 21 mm ltd's front element is about 20 mm away from the sensor, but should they see the exact same thing if the camera was positioned in the exact same place?
Just curious and hopefully someone here knows the answer right away.
04-01-2013, 11:07 AM   #2
The manufacturers use the diagonal of the sensor plate to determine the angle of view which is not very practical.
Also it is nominated at infinity focus.
For a retro focal wide angle like the DA21, it is simpler to visualize, the rear nodal plane is at f ( 21 mm ) from the sensor.
the AOV is twice the angle from the axis at the rear nodal plane N2 up to a corner at half of the diagonal
Using atan function on a calculator, it can be calculated, but easier just to look up the data published for the lens.
I just did a couple of examples (on 35 mm frame with a diagonal of 43.27 mm) ) and the values calculated as above agree with the values published by Pentax.
04-01-2013, 11:40 AM   #3
Mareket's Avatar
I've often thought this too. Surely it'd have an effect on close-ups, especially for wide angle? Not to do with calculating the AoV, but for the same AoV, if the front element is closer surely the picture will look different?
I guess to the extreme that you could be touching your subject with the 16-45 but not with the DA 21 and theoretically get the same picture which doesn't make sense. Neither would be in focus obviously, but still.
04-01-2013, 02:17 PM   #4
MSM
MSM's Avatar
Lol. @wombat you really hurt my head with that post. I am glad some here understand that stuff.
04-01-2013, 03:35 PM   #5
I love it when my curiosity is so easily satisfied...
Here is 21 mm @ f4 on the 16-45
Attachment 166089
Here is 21 mm @f4 on the DA 21
Attachment 166090
04-01-2013, 03:42 PM   #6
monochrome's Avatar
QuoteOriginally posted by MSM Quote
I think I remember atan from - was it Trigonometry? - in High School, but that was 40 years ago.
And there was an atan (or was it ArcTan) Function in Borland's QuattroPro.
Until today I never knew a use for either.
angle, angle of view, da, element, front, k-mount, lens, mm, pentax lens, sensor, slr lens, view
Quick question regarding field of view - FF vs APS-C glass? Julie Pentax SLR Lens Discussion 5 12-23-2012 05:33 PM
Samyang / Rokinon 14mm: Angle of View on APS-C richard balonglong Pentax SLR Lens Discussion 11 11-01-2011 07:22 PM
Lens' field/angle of view MK-x Troubleshooting and Beginner Help 11 06-06-2011 10:24 PM
250mm Gives Different Angle of View??? Snapshot12 Pentax SLR Lens Discussion 22 09-26-2008 09:03 AM
Confused about angle of view jzamora Pentax SLR Lens Discussion 3 03-20-2008 07:47 PM
All times are GMT -7. The time now is 10:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
