04-08-2013, 09:49 AM   #1
Pentax 60-250mm tight zooming
Hi. I've recently acquired this lens. First tests show excellent image quality. On zooming, though, the lens appears to be slightly "tight" starting at around 85-100 mm and feeling that way up to 200. From 60 to 100 it seems easier to zoom; same thing with 200 - 250. It may be that Pentax designed the lens to prevent any "creep" which might explain this or it may be that the lens is new. But i'm wondering if any other users have experienced this issue with this lens. Thanks! geraldan
04-08-2013, 10:01 AM   #2
QuoteOriginally posted by geraldan Quote
mine has a pretty consistent zoom feel across the range
04-08-2013, 10:06 AM   #3
VisualDarkness's Avatar
I've only used one very briefly but I can't remember it feeling overly tight at any length. Though it seems common with lenses that protrudes heavily when zooming, possibly due to air movement. As long as it's still easy to move and smooth I doubt there is any big problem and maybe it loosens up with time.
The zoom of Sigma 150-500 is overly tight in an attempt to prevent creeping but Sigma failed considerably in comparison and ended up a lens that creeps heavily with a very tight zoom ring.
Maybe somebody with the lens will answer.
04-08-2013, 10:19 AM   #4
panoguy's Avatar
My 60-250 zoom ring was a little stiff when new, but uniformly so. A little "working it in" and it's been fine ever since. No zoom creep, either! Very tight tolerances on the Pentax mechanism...
Not sure what you're experiencing, unless you find you're only moving between the lower focal lengths and not so much with the longer ones.
04-08-2013, 11:00 AM   #5
siamthai's Avatar
Mine might feel a little tighter at around 135mm but it's so little that it's hard to tell and nothing that I've noticed earlier.
04-08-2013, 12:27 PM   #6
mine is tight in the same range and one that I had before was. I have no zoom creep though.
04-09-2013, 06:18 AM   #7
Thanks
Thank you for all your responses!
04-09-2013, 01:17 PM   #8
AndrewG NY's Avatar
Mine is not 100% uniform in resistance across the range either, but I don't know that I'd call it especially rough or tight at any length. I don't think I've used it enough yet to determine whether this will change much over time.
I think for me the biggest surprise when mine first arrived was with just how much effective focal length is lost at close focus due to internal focus (IF) design. Practically speaking, maybe not such a big deal but I was kind of shocked how at minimum focus distance the field of view barely changes as you zoom from (say) 160-250mm to the point where I was initially wondering whether something was wrong.
04-09-2013, 01:38 PM   #9
AndrewG NY's Avatar
QuoteOriginally posted by VisualDarkness Quote
Agree, handled one and thought the same.
04-10-2013, 05:06 AM   #10
bdery's Avatar
QuoteOriginally posted by panoguy Quote
Mine was tigher at the tele end when new, now it's "almost new" but already I do not notice any difference in friction. The tight tolerances do mean there should never be any zoom creep.
k-mount, lens, pentax, pentax 60-250mm, pentax lens, slr lens
Pentax Zoom Telephoto 60-250mm halfspin Pentax SLR Lens Discussion 7 11-20-2012 06:37 PM
Pentax DA* 60-250mm @ 250mm vs DA 55-300mm @ 300mm resolution bwDraco Pentax SLR Lens Discussion 9 07-07-2012 05:16 PM
For Sale - Sold: Pentax DA* 60-250mm f4 Lance B Sold Items 4 10-11-2011 04:42 PM
Should the zoom ring on my 60-250 be this tight kwar Pentax SLR Lens Discussion 9 09-07-2011 05:50 PM
All times are GMT -7. The time now is 10:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
