04-10-2013, 08:09 AM   #1
Samyang/Rokinon 85mm - is it really f1.4 lens?
I took some test shot at f1.4 with newly acquired 85/1.4 and it seems to underexpose by say half stop at f1.4. Exposure seems to be correct for the smaller apertures (f2 & smaller). A few other people using it with Nikon also seems to have observed the same.
So wondering, are those lenses are really f1.4? To me, it seems like a f1.7 lens.
04-10-2013, 08:49 AM   #2
Maybe the discrepancy is due to the difference between T-stops and F-stops. a test of depth of field could tel you whether it is really opening to 1.4. It is highly likely the the aperture is 1.4, but the T-stop is 1.7. In fact, I think the cine versio the cine version lists a t-stop of 1.5.
04-10-2013, 10:03 AM   #3
VisualDarkness's Avatar
F-stops (aperture) is just a mere physical attribute of the lens, the relation between the focal length and the optical diameter, and actually doesn't tell how the light transmittance is. Though it does the you the depth of field and similar instead. For light transmittance you have to look at T-stops instead, commonly used for video equipment.
04-10-2013, 10:48 AM   #4
arv
Can't it be just vignetting? According to lenstip.com it is 0.8 EV.
04-10-2013, 12:09 PM   #5
Lowell Goudge's Avatar
Why not do a real test.
Take a series of shots against a block wall, and meter manually at an intermediate point like F5.6 and then take shots at each full stop from F1.4 thought minimum aperture, each time adjusting the shutter speed accordingly. Then take a photo editor that can measure the greyscale value inside a selection and plot greyscale vs aperture for the entire range.
If it is truly F1.4 you will have a flat line at about greyscale of 115-120 across the entire range.
If it is not F1.4 when wide open the greyscale value will drop below this. A 1/2 stop, as your implied 1.7 would be a greyscale 20-25 points below the central portion of your plot.
04-10-2013, 07:38 PM   #6
Probably T-stop difference.
Noticed it when comparing Canon EF50/1.8 vs A50/1.7 and S.Tak 55/1.8 on the same camera too. (the Canon always was 0.5-0.7 stop darker for the same exposure setting)
f1.4, k-mount, pentax lens, slr lens
Wanted - Acquired: 85mm f1.4 Samyang/Rokinon etc yusuf Sold Items 4 03-11-2013 10:50 AM
Portait lens - Pentax 50mm f1.2 (K version) or Samyang 85mm f1.4 Damon Pentax SLR Lens Discussion 17 01-21-2013 01:35 AM
Is internal dust common in new Samyang/ Rokinon/Vivitar/Bower 85mm 1.4? causey Pentax SLR Lens Discussion 7 12-01-2012 01:05 PM
Samyang/Rokinon/Vivitar 85mm f/1.4 Sol Invictus Pentax SLR Lens Discussion 40 03-31-2012 12:28 PM
For Sale - Sold: a Bevy of 85mm lenses: pentax-m 85mm f2k and Rokinon 85mm f1.4 gscara Sold Items 3 06-07-2011 07:56 PM
All times are GMT -7. The time now is 08:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
