03-05-2008, 06:38 PM   #1
What is difference "APO" and "ED" glass in a lens?
Is one definitely better than the other, or are there other possibly more important considerations in the lens?
03-05-2008, 07:07 PM   #2
aegisphan's Avatar
ED and APO is exactly the same thing: special glass design to reduce chromatic abberation. Nikon came up with the "ED" term 1st. Pentax and Olympus followed suit, while other manufacturers came up with their own term (Canon-LD, Minolta-APO, etc.).
03-05-2008, 07:17 PM   #3
Lowell Goudge's Avatar
I believe APO stands for aprocromatic lenses, i.e. lenses that have allignment of all 3 colors at more than one point (focus point)
ED glass, is extra low dispersion (low refractive index) glass, that helps achieve aprocromatic lenses
03-05-2008, 07:18 PM   #4
Ole
Ole's Avatar
ED is low-dispersion glass. Using ED glass for some of the optical elements in particular in tele-lenses help minimize color aberration.
03-06-2008, 08:59 AM   #5
Pentaxke's Avatar
Correct: APO stands for apochromatic lenses, and should should allign at least three colors (Blue, green, red) into the same point to prevent halo's around points or lines with big contrast. This is not the same as achromatic lenses, which only allign for two colors (Blue and red.) All lenses made these days are achromatic (or at least, they should be), but only some lenses (mostly the expensive ones and mostly telephotolenses) are apochromatic.
Note that apochromatic isn't the same for all brands: a Sigma APO lens would not be called apochromatic according to Leitz...
As for ED: that stands for extra low dispersion glass, which is used to help reduce chromatic abbarations...
k-mount, pentax lens, slr lens
Do custom "artistic" or even "funny" lens caps evenexist? lovemehate Pentax SLR Lens Discussion 33 02-10-2016 09:10 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
K-mount Experts: How to convert a "KAF2" lens to "KF"? panoguy Pentax SLR Lens Discussion 24 07-08-2010 05:20 PM
Pentax "A" lens and "F" 1.7X converter on K10d yyyzzz Pentax SLR Lens Discussion 4 07-09-2009 05:04 AM
"Hunger for a DA*50-135?" or "The DA*50-135 as a bird lens!" or "Iron age birds?" Douglas_of_Sweden Post Your Photos! 4 08-13-2008 06:09 AM
All times are GMT -7. The time now is 11:09 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
