04-16-2013, 09:47 PM   #1
Should I get A50/1.2 if I already have Voigtlander 58/1.4
I use the Voigtlander mainly for portrait and low light situations. There are some strong advocates of 50/1.2 on the forum and my LBA is calling.
Does it make sense to own both lens? What can't I already accomplish with the Voigtlander that requires a 50/1.2?
04-16-2013, 09:52 PM   #2
QuoteOriginally posted by chesebert Quote
You can't brag... And that's important, you know that too right?
Or, for example, if using the Voigt 58 enables you to shoot a tight headshot in a room measuring 1meter across, you can't do the same when you are forced to do the same shot in a room that measures 45cm across! Unless you have the A50/1.2! Ah-ha!
Neither can you shoot at a slightly faster shutter speed than needed! Who knows you insisted on shooting at ISO 100 and refuse to bump it up by 1 stop just because you don't want to! Ah-ha!
That's 3 good reasons for you to own it!
04-16-2013, 10:12 PM   #3
Digitalis's Avatar
To be realistic, there isn't anything that the Voigtlander lens can do that the Pentax K/A 50mm f/1.2 cannot, both lenses are excellent. The f/1.2 will allow for slightly faster shutter speeds than a f/1.4 lens will - you can also stop the f/1.2 lens down to f/1.4 for a marginal boost in resolution/contrast - but from what I have seen with the Voigtlander 58mm f/1.4 SLII on my Nikon D800E the differences between the two lenses would only be noticeable at the neutrino* level. I also use the Noct-nikkor 58mm f/1.2 ASPH on my D800E and there is a considerable difference between it and the Voigtlander - but that is because the Noct-Nikkor uses an expensive aspherical lens in its optical design and thus the lens is optimised for superior image quality at wider apertures**
Pentax K5IIs SMCP-K 50mm f/1.2
* as Michael Reichmann from the Luminous Landscape once put it "mouse nuts - really, really small"
**though image quality at smaller apertures isn't anything to write home about, these lenses sell for upwards of $6000 in Mint condition. The noct-nikkor is a bit of a rarity: less than 12,000 of them were ever made.
04-17-2013, 01:09 AM   #4
Moderator PEG Judges
Kerrowdown's Avatar
It will allows you to post on this thread, which you can't do just now
https://www.pentaxforums.com/forums/lens-clubs/74819-post-your-1-2-photos-1-2-only.html
04-17-2013, 03:18 AM   #5
Lowell Goudge's Avatar
Of curse get it, it wouldn't be LBA if you didn't.
Honestly though, I am not sure there is anything you can't do with what you have (talking of shooting wide open thatis)
04-17-2013, 06:38 AM   #6
I owned VL 58 twice, and I sold it twice. There was nothing wrong, VL 58 is very good lens, I just did not feel to it. (I ended having SL1 Topcor version finally, because it is a beauty). Contrary, I kept 50/1.2 Pentax primes and used them quite often. f1.2 allows to do some very interesting effects.
But the main reason is that 50/1.2 is more versatile. 58mm is sometimes too long for normal lens (especially, on APS-C) and too short as a portrait lens due to distortion.
From usability prospective, Pentax 50/1.2 is also slightly smaller and accepts 52mm filters and hoods.
You can always buy A 50/1.2 and decide which one to keep. Both lenses can be easily sold, there is a good demand on those.
04-17-2013, 06:50 AM   #7
MSL
MSL's Avatar
No you shouldn't. You should share the wealth, and if you buy it, give away the other to some poor lost soul, who thinks that buying a A50/1.7 or A50/1.4 too much of a luxury.
k-mount, pentax lens, slr lens, voigtlander
Quick Lens Comparison (Voigtlander 58/1.4, A50/1.7, A50/2.8 Macro) jeffshaddix Pentax SLR Lens Discussion 25 06-09-2014 04:29 AM
Should I sell DA*55mm 1.4 and get a DA 50mm 1.8? junototoro Pentax SLR Lens Discussion 11 03-02-2013 08:59 AM
Should I clean my A50/1.7 - or just call it a loss ? adr1an Pentax SLR Lens Discussion 5 07-31-2011 09:43 AM
Which Next Lens Should I Get? (I have 31, 77, 50, 18-250 Already) PentaxForums-User Pentax SLR Lens Discussion 3 06-15-2009 11:43 AM
another "should I buy?" thread: DA 70mm f/2.4L - I have a Tammy 28-75/2.8 & FA 50/1.4 m8o Pentax SLR Lens Discussion 11 08-26-2008 09:09 AM
All times are GMT -7. The time now is 03:29 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
