It is easier to design slower lenses - and it is also less costly to produce them from a manufacturing point of view as well. The glass blanks are smaller - which makes it more economical to order large quantities of them. The larger a glass blank is generally the more it costs to produce a optically perfect one from which a lens can be made, there is also the fact that slower lenses typically do not need the kind of optical aberration correction that faster lenses do*. Also faster lenses typically require exotic glass types to correct for optical aberrations as well, there is also the use of aspherical lenses - which require specialised machines and tools to create.
*Though this
really depends on the focal length of the lens.
Originally posted by Lowell Goudge Many lenses need to be stopped down 1-2 stops to be at the sharpest, the same number of stops down from 2.8 is still a stop faster than F4. Also. You still get a brighter viewfinder
Correct, though this does depend on the focal lengths of the lens and the optical construction of the lens as well. My sigma 100-300mm f/4 performs extremely well from f/5.6 -just one stop down, but a wide angle lens like the Pentax DA 16-45mm f/4 only performed consistently at f/8.
Originally posted by joe.penn DA*300 f/4 and the Sigma 100~300 f/4 are 2 top quality feature rich f/4 lenses.
Indeed they are but the Sigma doesn't have the kind of flare tolerance the DA*300mm f/4 does - one of the biggest faults of sigma lenses, I have panned Sigma for years over how bad their optical coatings are.
Though that hasn't stopped me from obtaining good Images from my Sigma 100-300mm f/4 APO EX DG
