03-06-2008, 05:44 PM   #1
Fix stuck aperture blades on Super Tak?
I have a Super Takumar 200mm that's very sharp wide open. The problem is, it's stuck wide open. Has anyone ever disassembled and repaired stuck blades on a Super Tak 200mm, or does anyone know of an available online guide for doing that?
I'd really like to be able to use this lens, from what I can see using it wide open, it's going to be very sharp stopped down a bit.
Thanks!
03-06-2008, 09:59 PM   #2
ryan s's Avatar
If you can't find anything via Google, you might want to join up and post in Maintenance and Repair section in the forum in my sig. I couldn't find anything with a search there, but someone might have taken one apart and not documented it.
03-06-2008, 10:34 PM   #3
roy
roy's Avatar
i haven't been inside the tak200 but i have been inside the 300. all of these seem to be built to a certain spec. once you get the lens module out there will be an aperture module incased in it. it's a separate unit that i haven't had to breach except in my 500/4.5 and it's fairly simple IF you pay attention. your prob is there is probably oil on the ap blades or there's a small cam lever that sticks thru the module that incases the lenses and engages the ap ring. if you're not mechanically inclined i'd suggest getting it repaired by a pro.. basically it's the same as THIS just bigger.. taking it apart and putting it back together tho takes some forthought..
200mm, aperture blades, blades, k-mount, pentax lens, slr lens
Super Tak 200/4 Aperture Problem breischl Pentax SLR Lens Discussion 0 10-30-2009 10:07 AM
ME Super Mirror Stuck up- easy fix?? tvfd911 Film SLRs and Compact Film Cameras 4 04-07-2009 06:04 PM
How to fix sticky/slow blades? TimB Pentax SLR Lens Discussion 35 09-22-2008 09:01 AM
How to fix oily aperture blades madhurvyas Photographic Technique 5 03-30-2008 02:21 PM
How to fix Oily aperture blades madhurvyas Photographic Technique 0 03-12-2008 01:03 AM
All times are GMT -7. The time now is 01:44 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
