04-20-2013, 05:52 AM   #1
i83N's Avatar
Recomend next lens.
I have some spare money, about 600$, and i want to buy some fix lens. Current line of work i do needs wide angel(even super wide). I have SMC Pentax-DA 10-17mm F3.5-4.5 Fish-Eye ED [IF] but it's fish-eye effect is pain to remove. I'm thinking about SMC Pentax-DA 15mm F4 ED AL Limited but as FF rumors heating up I'm want to invest in FF lenses too.
Any recommendation on fast sharp wide lens with FF range.
Or maybe i just go and buy SMC Pentax-FA 43mm F1.9 Limited for fun?
04-20-2013, 05:58 AM   #2
Ash
Community Manager
Ash's Avatar
If you want wide for architecture, DA 12-24 is excellent, but it's not FF compatible. For FF, you may consider the Sigma 12-24 lens that is FF compatible and considered superior to other Sigma wide zooms.
04-20-2013, 06:00 AM   #3
i83N's Avatar
Don't want zooms, fix are more compact.
04-20-2013, 06:08 AM   #4
Digitalis's Avatar
QuoteOriginally posted by i83N Quote
Well when it comes to compactness the DA15mm f/4 ED ASPH limited is the winning ticket here, I have a few full frame 15mm wide angles that are significantly smaller - but you would have to buy a Leica to use them.
04-20-2013, 06:11 AM   #5
Moderator PEG Judges
Kerrowdown's Avatar
Have a think about one of these SMC Pentax-A 15mm F3.5, wide, rectilinear, prime, FF and should be on budget ish if you can find one, I love mine to bits, just not autofocus but with huge dof it's not normally an issue.
https://www.pentaxforums.com/lensreviews/SMC-Pentax-A-15mm-F3.5-Lens.html
04-20-2013, 06:15 AM   #6
i83N's Avatar
My thoughts exactly....
04-20-2013, 06:17 AM   #7
Digitalis's Avatar
QuoteOriginally posted by kerrowdown Quote
The problem being that lens has a front element nearly twice the size of the grotesquely bulbous sigma 8-16mm f/4.5-5.6 - also the DA15mm f/4 can be used with regular 49mm filters - slim frame filters are unnecessary, unless you are stacking filters.
04-20-2013, 06:31 AM   #8
Kerrowdown's Avatar
grotesquely bulbous
That's one of her inherent beauties, along with the lens cap that falls off when you just look at it.
But she still is wide, rectilinear, prime, and FF, in her defence.
04-20-2013, 06:32 AM   #9
If your subjects are static, stitching might be one option.
If you have a job to do now, over the next year or so,
then the mythical Pentax FF won't help you.
The DA 15 is available and useful now!
04-20-2013, 06:34 AM   #10
oxidized's Avatar
If you are okay with manual focus, then you cannot go wrong with the samyang 14mm (also sold under rokinon/bower/bell and howell and weirdly vivitar 13mm). sharp all over, straight from wide open. (AND FF compatible)
04-20-2013, 06:35 AM   #11
Kerrowdown's Avatar
QuoteOriginally posted by lytrytyr Quote
That maybe so, but the original OP did say... and it can still be used now also.
04-20-2013, 06:46 AM   #12
Digitalis's Avatar
my thoughts exactly - K mount APS-C cameras aren't going to suddenly vanish as soon as a pentax FF is announced.
Pentax K-7 - Pentax SMCP-DA 15mm f/4 ED ASPH Limited
04-20-2013, 06:47 AM   #13
"Invest" if the FF is imminent.
"Squander" if it isn't!
04-20-2013, 06:53 AM   #14
Na Horuk's Avatar
Even if Pentax releases FF, it will still be able to use DA lenses, to some extent (in-camera crop mode, or post process cropping). And they will probably announce another crop flagship, as well.
Btw, did you look at the Voigtlander 20mm? Its pretty compact. But no AF and not quite that wide on crop. Also, quite rare, but not as expensive as Zeiss.
Zeiss also used to make some very wide angle primes in Kmount and m42. Again, no AF, and very expensive.
Oh, and Samyang has announced a 10mm lens recently? Not sure how compact it is, though. The 14mm Samyang is pretty big and heavy.
04-20-2013, 06:55 AM   #15
i83N's Avatar
Less post processing better for me.
ff, fish-eye, k-mount, lens, pentax lens, pentax-da, slr lens, smc
Anyone recomend a 135 for music venue? maverick75 Pentax SLR Lens Discussion 15 04-27-2013 04:08 PM
Next Lens? Scottie137 Pentax SLR Lens Discussion 9 05-22-2012 11:12 AM
Next lens suggestion? mhaws Troubleshooting and Beginner Help 17 05-31-2011 09:25 PM
Would you recomend Pentax lenses (system) dfujevec Pentax SLR Lens Discussion 15 09-04-2010 10:37 PM
Please Recomend Lens for K100 papabeagle Pentax DSLR Discussion 2 10-16-2006 07:53 AM
All times are GMT -7. The time now is 03:36 AM. | See also: NikonForums.com, part of our network of photo forums!
