Originally posted by jshurak If you're taking landscapes get the graduated ND. It's crucial to balance the exposure between the landscape and a bright(er) sky. The cokin set will work with all three lenses, provided you have either 1)three cokin filter rings (one for each lens) or 2) step up(down) rings for each filter size.
Get a few different ND grads if you can. Depending on how much money you are willing to spend this can be easy or difficult. Grads typically come in different stop adjustments and the actual graduated part can be a hard or soft grad. The hard grads are great for sunsets where the sky is brightest at the horizon. The softs are better for earlier in the day.
If you're willing to spend some loot, look for a good set of them. I here people talk about Lee filters. They're pretty pricey though. I went with the cheap route and picked up a couple of grad nd4's I think. They're stackable so I can get an 8 stop difference.
The square filters are the way to go. The Cokin standard filters are plastic, and can be scratched. (How do I know, you say?) The Lee filters are, I believe, glass, and are less prone to scratches.
