12-31-2008, 10:49 AM   #301
9023610 was shipped back as a replacement for my first lens. It works just fine.
John
01-08-2009, 09:17 PM   #302
jpzk's Avatar
Here is my ten-cents-worth of help:
S.N.: 9014661Works great on both K10D and K20D sinceI bought it in October 2007.
JP
01-10-2009, 03:11 PM   #303
S/N 9029891 purchased online from B&H last week is my second and this one is going back also. Not as bad as the first but a very poor image everywhere but the center, especially at f16. I may try a third but this is all very disconcerting.
01-20-2009, 04:59 AM   #304
fadzil karim's Avatar
S/N 9015461 bought here in Kuala Lumpur, Malaysia. Work well with my K10D and luv it
01-31-2009, 02:02 PM   #305
Ash
Community Manager
Ash's Avatar
S/N 9029707 bought from KEH last week.
Brick wall test: not as impressive as I'd hoped.
Significant vignetting and barrel distortion at 16mm, even more than 16-45 lens, but sharpness acceptable throughout.
More tests to follow...
01-31-2009, 02:26 PM   #306
Presto's Avatar
After some fairly rigorous tests, I can say that lens: SN 9032916 is in perfect working order on my K20d. I got a good one on the first shot! It's a truly fabulous short zoom, and fun to use. No regrets on getting this one!
02-01-2009, 07:53 PM   #307
StevenVH's Avatar
SN 9029429 is good optically, but the zoom ring gets much tighter from 28-50. Is this common? It bugs me and I'm considering sending it to Pentax when I can be without it for a while.
It was bought from Amazon 7/08
I took the lens and body with me to work at sea last time and for 3 months it was on the cam 75% of the time. I bounced it from Lisbon, all around Italy, past Gibraltor twice, then to Brussels, Rotterdam, Amsterdam....that kit has been hot, cold, fogged, hot and wet, cold and wet, rained on, snowed on...I had ice form on the edges of the filter during Nov in Rotterdam.
Great stuff. The lens looks new, the body has a few scuffs and I've absolutely no prob's with either yet.
02-01-2009, 09:55 PM   #308
QuoteOriginally posted by StevenVH Quote
Yes, this is normal from what I've read. It's because there are two zoom barrels, and the second is engaged around 28mm
02-01-2009, 11:40 PM   #309
Tdo0003's Avatar
QuoteOriginally posted by thear Quote
9019346 from Willoughby's appears to be good. I tested the lens with the focus test chart, newspaper, and flowers.
looks like yours is the exact SN another member has reported as "bad"...
02-02-2009, 07:52 AM   #310
StevenVH's Avatar
QuoteOriginally posted by EricT Quote
Okay, thanks for that. I was starting to think it must be by design, but hadn't seen it mentioned by anyone else yet.
cheers
02-04-2009, 12:14 AM   #311
I have 9030708. Bought it from B & H. No problem using it with my K200D.
02-05-2009, 01:24 PM   #312
#9025151
Now it is perfekt. But: SDM two times colapsed and was repaired in Hamburg Germany during last 8 months.
Still recomended.It is nice glass.
02-05-2009, 03:01 PM   #313
MCR
#9029820 - first and perfect. I still recomended too.
02-09-2009, 12:13 AM   #314
S/N 9029255 purchased 2/09 from Adorama. BAD.
Decentering right, which looks downright appalling by 36-50mm when it adds ghosting to the left side's blurring and yellow-blue CA. Front focuses at all focal lengths except 16mm and 50mm, which means it's not correctable in-camera.
Sending it in to Pentax rather than gamble on store replacement. Will post an update after servicing.
On the bright side, it's clearly worth the initial hassle. The AF locks in fast and without hunting, the 16mm test shots promise that a properly calibrated version of this lens can deliver spectacularly, and the SDM really is practically silent. The mirror slap is jarringly loud by comparison.
Last edited by cczona; 02-13-2009 at 06:37 PM. Reason: removed extra "9" from serial number
02-09-2009, 02:19 PM   #315
NeverSatisfied's Avatar
9011857- Defective
Purchased December 2007 from Beach Camera. Replaced under warranty by Pentax.
9012375, the replacement, is a very good copy.
16-50mm, copy, da*, da* 16-50mm, k-mount, pentax lens, serials, slr lens
Lens Serial Number Database Ole Pentax SLR Lens Discussion 58 03-28-2017 04:41 AM
K1000 Serial Number Database Ole Pentax Film SLR Discussion 233 02-26-2012 10:30 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Pentax 50mm f/1.2 lens serial number id? sandpipe Pentax SLR Lens Discussion 8 08-25-2008 05:55 AM
All times are GMT -7. The time now is 03:45 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
