01-02-2010, 11:57 PM   #421
esman7,
I can't honestly tell if you got a good copy or not, with those tiny photographs. However the vignetting doesn't look too bad, at 16mm for any wide angle zoom lens.
I honestly like the effect that you have on your first image.
01-03-2010, 02:38 AM   #422
QuoteOriginally posted by esman7 Quote
...and these are the ones at 50mm FL.
Pics at f2.8, 4, 5.6, 8, 11
Test Pentax smc DA* 16-50 mm f/2.8 AL ED IF SDM - Winietowanie - Optyczne.pl (I doubt you need a translation.)
Test Tokina AT-X 165 16-50 mm f/2.8 PRO DX - Winietowanie - Optyczne.pl (The design of the Tokina is almost identical to the Pentax.)
01-03-2010, 02:47 PM   #423
S/n: 9025890
Bought it one year ago at amazon.
Backfocused on the K10D (corrected in Debug), spot-on on the K-x. (as are all my other lenses).
When corrected, very sharp, good rendering, no SDM issues.
Have never really checked for distortion or corner softness, as it is not a major concern for me.
D.
01-03-2010, 05:09 PM   #424
esman7's Avatar
QuoteOriginally posted by little laker Quote
esman7,
It really does come up at the extreme end and I was concerned until...
QuoteOriginally posted by asdf Quote
...these links showcase it on a neutral background and now I am not surprised.
Is vignetting usually then an inherent characteristic of wide angle lenses (at their widest end)?
(Thank you for the links asdf)
01-05-2010, 11:07 AM   #425
Take a look at tests of Tamron 17-50 f/2.8 or other fast zooms. It's a much liked lens and it behaves similarly at f/2.8.
http://www.optyczne.pl/30.8-Test_obiektywu-Tamron_SP_AF_17-50_mm_f_2.8_XR_Di...ietowanie.html
01-05-2010, 01:22 PM   #426
esman7's Avatar
Phew, thanks for putting that one up because I was worried I would have to get the Tamron instead.
01-07-2010, 06:20 AM   #427
I still read people receiving low numbers. How odd.
Received my 9026xxx in august 2007.
It worked fine until 2.5 weeks ago (dec 20th) my zoomring got stuck....
Need that lens again i fenruary so knowinig how stores and the new Pneatx service works I decided to get me a new one, repair probably costly.
Then after some, no, a lot of shipping mishaps, I recieved the lens on monday after Christmas. This one being a 9029xxx (forgot number).
At last I am a true Pnetaxian, AF did not work.
Sent back an no replacement yet....
Full rant here....
I do ahve a long rant, failing DA*....: Pentax SLR Talk Forum: Digital Photography Review
01-07-2010, 12:28 PM   #428
QuoteOriginally posted by janneman Quote
While it miht have been a bit more expensive (well, it was on sale so maybe not), this is why I got my DA* 50-135 from a local retailer. I was able to test and inspect the lens before I signed for it and I could return it if it was defective.
01-12-2010, 05:48 PM   #429
Pentax 16-50mm, Failed SDM motor - Repaired
Serial #9030726
SDM motor failed.
Sent to Chandler, AZ repair facility on Dec. 22. Received repaired lens on January 8th - they replaced the motor under warranty. Pretty quick turnaround - and lens looked well cared for.
Now praying that the motor doesn't fail after warranty is up.
Plan to exercise it every day and not let it sit too long.
01-17-2010, 10:13 AM   #430
Fourth digit still important who knows why
Hi everybody,
More Bayes nets with updated list of S/N (as of 17Jan2010): there is still a 65% random chance to get a good copy, and 90% if the fourth digit is 0, 1 or 2. The digit to check is the X as in 902X306. So if you have the possibility, you could improve your odds by asking for a fourth digit <= 2 !
EDIT: actually, if 4th digit = 0, chance of a good copy is 90%, if it is =1, chance is 100% (!), if it is =2, chance is 77%.
Cheers,
Grégoire
PS: sorry for you mdsnexp, you had a 10% chance of getting a lemon...
01-18-2010, 12:43 AM   #431
-Mous-'s Avatar
SDM failed
Ok, after 7,5 months, my 16-50 has stopped focussing. The SDM doesn't do anything anymore.
Serial number: 9023606
Bought it the 28th of may 2009 in the Netherlands. Bringing it back for warranty this afternoon.
[edit]
I just signed the petition. By the way, my 16-50 broke down quite gradually. At first the focussing got slower, then it got even slower with more hunting (sometimes not focussing at all), and in the end the SDM didn't do anything anymore. My other two SDM lenses (see sign.) work perfectly.
01-18-2010, 02:13 AM   #432
PentaxPoke's Avatar
QuoteOriginally posted by -Mous- Quote
Sorry to hear that Mous. Many of us feel your pain. About all you can do is send it in under warranty, and sign the petition:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/81324-superson...-reminder.html
01-18-2010, 10:36 AM   #433
esman7's Avatar
QuoteOriginally posted by le_roi_ponpon Quote
Hi everybody,
Cheers,
Grégoire
That's wonderful information Grégoire. Thank you for conducting the analysis.
01-20-2010, 09:10 AM   #434
Moe49's Avatar
9031008
So far no problems with s/n#9031008. I bought this lens via Amazon in Nov, 2009.
I have used it lightly, ~200-300 shots. I am very happy with it's optical and focusing performance.
After finding this web site recently and this thread today, I'm getting nervious about it and the DA*50-135mm lens I ordered this week.
--Moe--
K7, DA*16-50mm, DA*50-135mm
P3N, SMC-A 50mm, SMC-A 70-210mm
01-24-2010, 04:12 AM   #435
#9026888 has focussing problems at 50mm end of zoom - have to manually focus or bring back in a bit. About to return under 2 yr warranty as 1 year and 1 month after purchase. Purchased from Digital Depot UK in Dec 08 (replaced my previous delivered faulty one, don't know serial no., but had serious CA problems)... no SDM issues on this or my 50-135 DA* so far....
16-50mm, copy, da*, da* 16-50mm, k-mount, pentax lens, serials, slr lens
Lens Serial Number Database Ole Pentax SLR Lens Discussion 58 03-28-2017 04:41 AM
K1000 Serial Number Database Ole Pentax Film SLR Discussion 233 02-26-2012 10:30 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Pentax 50mm f/1.2 lens serial number id? sandpipe Pentax SLR Lens Discussion 8 08-25-2008 05:55 AM
All times are GMT -7. The time now is 08:51 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
