07-14-2008, 01:11 PM   #106
9014806 seems OK - no strenuous testing yet, but test chart looks good...
Bought at Henry's, Kingston, Ontario, Canada
07-16-2008, 10:57 AM   #107
9011905 - Good
Wanted to wait a while before posting, to make sure
9011905 - Good
Aden Camera (new), Toronto, Ontario Canada
AF is correct on K20D (no Bf, no FF with no AF adjust applied on camera)
Not de-centered (center of focus is center of image, left and right OOF area equal)
07-16-2008, 12:08 PM   #108
fishy: i would vote 9029381 is good.
that looks on par with my fast fifties at 2.8, fully cropped.
anyone think it's bad, i like to see a 'good' example in comparison.
07-16-2008, 12:30 PM   #109
fishy's Avatar
QuoteOriginally posted by truonganh Quote
Thanks, been fishing for those myself. (if possible black print on white paper.. )
07-20-2008, 06:33 AM   #110
fishy's Avatar
Just to check; should the DA16-50 be outperformed by the FA 50 2.8 @ f/5.0? (Mine is)
Voting 9029381 bad
07-21-2008, 09:24 AM   #111
How can you know BEFORE buying the lens if it is good or not !??!?!
07-21-2008, 11:20 AM   #112
jsherman999's Avatar
QuoteOriginally posted by fishy Quote
Voting 9029381 bad
??? Yes, by all means, the FA 50 f/2.8 should outperform the 16-50, at f/5 and even f/2.8... Did I understand your question correctly? A prime will almost always outperform a zoom, especially the FA 50 2.8 macro, which outperforms pretty much anything.
07-21-2008, 11:26 AM   #113
fishy's Avatar
...A prime will almost always outperform a zoom...
In that case I might have to review my verdict; The da* @ f/5.6 at least matches the FA50 @ f/4.0 in crispness/sharpness. I might have been thrown off by bright light and hard contrast; my DA* suffers a lot from purple fringeing. Less light and it gets better.
One bad of mine: the FA is not the macro but the 1.4. (Sorry)
07-21-2008, 11:31 AM   #114
Ah. But the answer is still yes, the FA 50 1.4 at f/4 is sharper than pretty much any zoom you can buy, including the DA* 50-135.
If your 16-50 at f/5.6 matches the FA 50 at f/4, then I'd say you have a very good copy based on that alone.
You could test for centering defects, FF/BF in low tungsten light (tricky for almost any lens,) but really you should get out and take a whole bunch of real-world shots and see how much it pleases you.
07-21-2008, 11:56 AM   #115
fishy's Avatar
Thanks a lot for that jsherman. Maybe my expectations were just too high..
Dont want to be a measurbator (as demonstrated by limited skills) but unforunately I have very little time to see if the lens is good enough. I'll be leaving for East Timor shortly for an unknown time, so returning it from there would be ... tricky at best.
I will let it rest from here. Sorry if I abused this thread!
07-23-2008, 09:52 PM   #116
suro's Avatar
16-50*
I bought my Pentax 16-50* /2.8 lens recently a few days in Ekaterinburg (Russia). Number is: 9024487. By my personal opinion - is good lens. Few samples at f2.8:
Newspaper 100% crop:
My kitty (resize and 100% crop):
Flowers (resize):
Old newspaper (full size 10Mb JPEG):
http://ifolder.ru/7444451
P.S. Simple soft border - it's normal for must lens (and fix focal lens too).
07-23-2008, 10:35 PM   #117
i was about to buy a 16-50 awhile ago, but thought about asking here first... what should i look out for in the store? obviously, if it focuses sharp, BF/FF issues and what else? i'll be purchasing the lens tomorrow morning, just want to see what you guys would suggest on how to test..
07-23-2008, 11:02 PM   #118
suro's Avatar
QuoteOriginally posted by leadbelly Quote
You must check:
1. Manual focus work.
2. Back and front focus (take the foto of plain text on the f2.8 by 45 degrees).
3. Sharp at f2.8 (take the photo of newspaper). Border of photo may by simple soft - it's normal for crop lens.
4. Auto focus work.
07-23-2008, 11:19 PM   #119
suro's Avatar
Mup 40M 20mm /3.5
For example (about soft border):
Center and corner, full frame fix focal 20mm lens on the crop body. Line 2 - by center, line 3 - by corner
07-24-2008, 06:17 AM   #120
I just got my 16-50, and after a few test shots, it seems like a good copy. a few questions though...
1) Is the zoom ring really a little stiff, especially around 28-35mm? Unlike the 50-135 that's smooth? (Is it because of the weathersealing in the front part of the barrel where the lens extends?)
2) Focusing wide open is sharp at 50mm, but when I focus at 16mm, it's a little soft. Is this normal when used with the K10? (as with my 50-135, focusing is soft at the wide end, whereas focusing at the long end is hella sharp... but when I tried the 50-135 on a k20, it was sharp all the way.) Is this a K10D only issue?
Thanks!
16-50mm, copy, da*, da* 16-50mm, k-mount, pentax lens, serials, slr lens
Lens Serial Number Database Ole Pentax SLR Lens Discussion 57 04-17-2016 09:58 AM
K1000 Serial Number Database Ole Pentax Film SLR Discussion 233 02-26-2012 10:30 AM
Serial Number Database royal07 Pentax SLR Lens Discussion 1 10-15-2010 05:04 PM
Pentax 50mm f/1.2 lens serial number id? sandpipe Pentax SLR Lens Discussion 8 08-25-2008 05:55 AM
All times are GMT -7. The time now is 11:37 PM. | See also: NikonForums.com, part of our network of photo forums!
