Originally posted by KDAFA Well ddamski, I do hope you will succeed to solve your autofocus accuracy problems with your FA77.
But as DSims highlighted above, a good lens is much more than just about sharpness. But it appears that many these days evaluate a lens primarily based on sharpness.
Well, if a particular lens is having actual focus issues or construction problems, leading to unacceptable softness, then yes, you do have a problem on your hands.
But if that is not the case, then sharpness is merely one aspect of a lens' overall performance.
Other things come to play, eg the colour rendering, 3D effect, microcontrast, bokeh character, image 'purity' and so on. These aspects are often overlooked (or unappreciated perhaps). To some extent, an over-reliance on laboratory-based lens testing is contributing to this problem. Test charts do have their usefulness but there is much more to a lens, which can only be detected through actual field usage and experience using the lens to understand its character.
Therefore, to evaluate a lens purely on lab test results, in particular shaprness, is quite dangerous and can well miss the whole point of the lens.
hello kdafa,
thanks for your answer. I know that also other criterias are important. But imagine how i felt, wenn i went for vacations, took some pics with my 77 and found out that it had an focusing issue
In the moment i dont have focusing issues, i fine tuned it through my K5 to a +10. (even though a 12-13 would be better if it was possible). But my thread was mostly a comparison. For me it was quite interesting checking the bokeh and the sharpness. Just for info and not burning the DA40mm i want to mention that i had a wrong fine tune adjustment of +6. This lens works better with 0. So my previous foto samples of the 40mm are not focused accurately.
Originally posted by Sandy Hancock Which Sigma zoom is that? I have the old EX DG II 70-200/2.8 HSM macro (not OS) and it fares *much* better than this. Consensus has it that the newer (OS) version is much better.
It is the first of the Sigmas 70-200, non Macro, Non DG. I also know that this lens performs better than the new ones. My copy is just not the sharpest at 2.8. After 5.6 it is doing very well.
Originally posted by JinDesu That Sigma doesn't look so bad on the 200mm end. That's usually the weakest of all the 70-200s. It's a bit weak on the 80 end though. As Sandy says - some of the Sigma 70-200s aren't that great.
I also had the Tamron 70-200 and i think it is sharper than the Sigma i have now. But i didnt liked always the color rendition of the Tamron. Maybe in the future i have a Pentax tele lens
