Originally posted by steve1307 I lost the one from my 18-135WR too.
Annoyingly the one from the 18-55WR is exactly the same width, and is the same curvature (even though its 52 vs 62) but the cover is 1mm "less deep" so does not click into place. It wont stay in.
DIY solution looks the way to go where it's absolutely necessary.
Yeah, I tried that and found the same. I understand that different engineering teams at Pentax, as well as every other manufacturer, work on independent projects, so there's bound to be differences in the way accessories work. I just wish there
would be more cross communication. It would make life so much easier for we consumers.
Originally posted by percy More of an issue if you fit the hood with the window at the top!
I hadn't even realized the window could be at the top until I started investigating a solution. I've only had the lens for a few days and hadn't swapped lenses yet.
I may wind up getting a screw-on collapsable hood. I saw a few that also have female threads inside to use a filter. In the meantime I've cut a rectangular piece of thin foam rubber insulation and secured it over the window with one of those elastic wrist bands that Lance (formerly well-respected) Armstrong made popular. Seems to do the job and I can lift up the edge so I might still be able to use a polarizer.
Thanks everyone for the suggestions, even the tongue-in-cheek ones
