Hi lastdodobird
Re your observation:
Quote: I use it (the Sigma) at 20mm.......I've discovered that when you use it an any lesser focal length with the built-in flash, a shadow is cast at the bottom of the pic.
I own both the Sigma 10-20mm & Tamron 18-250mm superzoom and have observed that if you attempt to use the in-built flashgun on the Pentax K10D whilst leaving the respective lens-shade on either of these lenses at their widest settings, the
close proximity of the flashgun to the lens-shade virtually guarantees that an inevitable shadow will be cast at the bottom of each image. The solution to this problem is simply to remove the lens-shade if using these lenses at their widest setting, when using the built-in flashgun......it's a minor inconvenience but gets the job done !
Best regards
Richard
