Originally posted by bdery Without knowing WHY the 55-300 isn't pleasing you, it's hard to answer your question. If it's a matter of IQ, then I doubt the Sigmas will impress you a lot. The DA* will. If it's a matter of reach, then you might be better off buying a camera with more resolution (depending on your current body) and crop. But the Sigmas WILL give you more reach.
Good summary.
I am not satisfied with the resolution of the DA 55-300mm, nor was I satisfied with the resolution of the Sigma 150-500 HSM OS. I am totally satisfied with the resolution of the DA*300mm, even with my Kenko PZ 1.5X TC attached. Unfortunately, AF with the Kenko is unreliable on my DSLR's, but works fine with my K-01. I have high hopes that we will see the roadmapped Pentax TC soon. I intend to buy a 24mp K-3 when available, for harder cropping.
I often shoot the DA*300 at f4, because in the northern Ontario woods, and in the evenings, light intensity is
low. Having 300mm @ f4 and 420mm @ f5.6 works for me.
Originally posted by bdery My personal opinion is that, as much as I like primes, for tele I could never work with only a prime, so I went with the 60-250. Best decision I took in a while.
I considered the 60-250 for a long time. In the end I decided on the 300mm for two reasons. With a long tele lens, I often alternate between close-ups (dragonflies, butterflies, flowers, etc) and very long shots. The prime has much better close focus ability. This was more important to my style of shooting than the ability to zoom out. Normally, I have a second body with me when shooting long.
Secondly, the prime is a longer lens. It's not just that 300mm is longer than 250mm, but also because the zoom loses more range at distances below infinity due to internal focus. When you add a TC, these effects are compounded. The 60-250 is a great lens, but I decided the prime was best for my uses.
