Originally posted by mcook Silly question I suppose...but on my top LCD screen the it only displays the shutter speed and this "F-- " The F is not flashing, it just doesnt diplay anything. Does that sound right?
Initially the F was flashing because you did not have the aperture ring enabled via the rear menu. Since you enabled it, the "F--" is just an indication that the camera body is unable to read the aperture (f stop) setting from the ring, since it is a manual lens (it does not have the electrical contacts on the mount to communicate with the camera body). This is normal for M42, K, and M lenses. A, FA, FAJ, DA, DFA and DAL lenses all have the electrical connections to communicate the aperture to the body from the lens.
After you take a picture, you can go take a look at the EXIF data on the image and you will see that the aperture is defaulted to f2.4 (if I remember correctly). You might have taken the picture at f8 but the body does not know it, and it needs to put something in the field.
This is again why you need to use the green button. You can open the lens up all the way to get the light to focus accurately, then stop down (by turning the aperture ring to say f5.6 if that is the aperture you want to use), then push the green button so that the camera will meter with the light that is coming through the lens. If you are in AV mode the camera body will adjust the shutter speed to the detected amount of light and then you can take the picture. If you are in manual mode, you need to take a look at the image and then adjust either the ISO, aperture or shutter speed accordingly.
