05-22-2013, 09:49 AM   #16
bdery's Avatar
But how? Is it standard in modern AF lenses, in a chip somewhere? Focal length, aperture etc I can understand being transferred to the body by the lens, but the MTF performance profile?
Exactly. The lens communicates a lot of information about itself.
Just think about newer Sigma lenses which can be updated via USB. Or some flashes which must be updated ("re-chipped") periodically. There's a lot going on inside these components.
05-22-2013, 10:10 AM   #17
In lens disassembly tutorials you'll typically see a flexible PCB mounted on the inside of the barrel somewhere, with one or more chips on it. Basically you need something to decode a pattern that allows determining the focal length (think rotary encoder), and a couple hundred bytes or so worth of EEPROM. Nothing too fancy even by the standards of 20 years ago, it just has to work reliably.
Incidentally, I had the same issue of different AF performance on different camera lately. A Pentax 16-45 showed noticeable backfocus on my K-x, but was spot-on on a K-5. Go figure. All I can think of is that the AF sensor sees through a different part of the lens or somesuch, and a non-ideal lens alignment then causes these discrepancies. This sort of problem seems to be pretty much limited to complex zooms with multiple moving lens groups, probably because a lot can go wrong mechanically in those, in terms of tolerances and whatnot.
adjustment, af, bodies, f2.8, k-5, k-mount, k-x, lens, pentax lens, results, slr lens, tamron
Can Tamron 28-75 replace DA 35/2.4 and A 50/1.7? ChooseAName Pentax SLR Lens Discussion 16 04-10-2013 11:05 PM
sell Tamron 28-75 for a Da* 16-50mm? nick52 Pentax SLR Lens Discussion 11 12-21-2012 07:21 PM
Wanted - Acquired: WTB: Tamron 28-75; Tamron 1.4x AF TC chickenandavocado Sold Items 2 08-08-2011 03:17 AM
Tamron 28-75 from a da40? Metalwizards Pentax SLR Lens Discussion 7 07-19-2011 12:28 AM
For Sale - Sold: K10D, Tamron 28-75 F2.8, Tamron 75-300 F4-5.6, Super-Tak 50/1.4, AF-360 Flash maconmatt Sold Items 5 10-25-2010 06:18 AM
All times are GMT -7. The time now is 06:07 PM. | See also: NikonForums.com, part of our network of photo forums!
