05-17-2013, 12:01 PM   #1
tomwil's Avatar
Pentax DA 18-250mm lens hood substitution
Does anyone know if the Tamron 18-250mm Di-II lens hood would work as a substitute / replacement for the Pentax DA 18-250mm lens hood? Would the Tamron lens hood fit the Pentax lens?
The Tamron RHAFA018 hood is 1/3 the cost of the Pentax PH-RBB62 hood. For a $30 savings, I can do without the Pentax nomenclature if the Tamron hood would fit.
Thanks for any suggestions!
05-17-2013, 12:28 PM   #2
From what I gather, it works as a replacement. Must just not have the little insert for CPLs.
Edit: Disregard the cutout. The lens was entirely a rebadge from Tamron, the hood should most likely fit.(Neither version has the insert anyhow)
05-17-2013, 01:50 PM   #3
I have both lenses. I will check them as soon as I get home. As I recall, there are not interchangable.
Please stay put. I will post it tonight or tomorrow.
05-18-2013, 12:17 AM   #4
EarlVonTapia's Avatar
I have a Pentax da 18-250. I am using the Tamron da18 lens hood that was meant for the tamron 18-250. it fits PERFECTLY. I can provide photographic evidence if necessary.
enjoy.
05-18-2013, 08:47 AM   #5
tomwil's Avatar
Thank you for all of the replies.
I found that this question was asked earlier in an older thread, with the result saying that the attachment was different. However, I trust EarlVonTapia's reply since he actually has the DA18. I'll be placing an order with B&H soon.
Also, just for note, the Tamron lens hood from a 18-200mm lens does not fit on the Pentax DA 18-250mm lens.
05-18-2013, 05:33 PM   #6
The Tamron 18-250 hood fits the Pentax one. I have both and the hoods are interchangeable.
I will post some pics later.
The hood for the Tamron 18-200 does not fit. I also had one of those.
05-18-2013, 07:20 PM   #7
Pictures (too slow jjdgti!)
With hood in correct position:
https://www.dropbox.com/s/q606tetuih9rsrh/20130518_191023.jpg
With hood in storage position (so you can see the DA18)
https://www.dropbox.com/s/2h5qhfaxqm04igv/20130518_191254.jpg
I got my DA 18-250 without the hood. Luckily I found the Tamron hood for $2 at a recent camera gear swap.
Enjoy tomwil.
05-20-2013, 07:46 AM   #8
tomwil's Avatar
Thank you, EarlVonTapia and jjdgti, for the verification.
I ordered 2 of the Tamron hoods from B&H, but they are out of stock, and hopefully they come in soon. Seems to be a popular item. I'll be patient.
Sure wish I found the bargain that EarlVonTapia got!
Thanks again!
08-29-2013, 08:10 PM   #9
tomwil's Avatar
QuoteOriginally posted by tomwil Quote
Just got word that B&H now has these in stock (after 3 months) and has shipped my order.
Gotta give B&H a lot of credit. They kept me informed of the backorder status, and didn't cancel the order even after 3 months.
Can't wait to try these out. Thanks again, EarlVonTapia and jjdgti!
08-29-2013, 09:34 PM   #10
No problem!
It might seem tight at first, but as you remove it over and over again the teeth will file down naturally, giving it a snug, secure, and natural fit.
09-05-2013, 06:09 AM   #11
tomwil's Avatar
Received my order from B&H, and the Tamron DA18 hoods work perfectly on the Pentax DA 18-250mm.
I appreciated B&H's use of a well-packed box, rather than Adorama's use of envelopes. Thanks again, everyone!
da, da 18-250mm lens, hood, k-mount, lens, pentax, pentax da 18-250mm, pentax lens, slr lens, tamron
Newly acquired 18-250mm Pentax DA lens issues compared to 55-300mm AH11 Pentax SLR Lens Discussion 4 12-09-2012 08:28 AM
Which Zoom Lens? "Tamron AF 18-250mm", "Pentax-DA 18-250mm" or "Sigma 18-250mm" hoomanshb Pentax SLR Lens Discussion 4 07-30-2010 09:50 AM
Questions about DA 18-250mm lens hood jpoint Pentax SLR Lens Discussion 3 06-12-2010 07:16 PM
Does lens hood come with DA 18-250mm? Ron_Man Pentax Camera and Field Accessories 4 06-05-2010 10:07 AM
Pentax DA 18-250mm Zoom Lens Hood shutterbob Pentax SLR Lens Discussion 3 12-18-2007 11:26 AM
All times are GMT -7. The time now is 04:06 AM. | See also: NikonForums.com, part of our network of photo forums!
