Thank guys, I bought it for portraits, so I'll have enough time to focus either with live view or viewfinder (fortunately K30's viewfinder is really bright and clear)
Originally posted by Na Horuk I suggest you look at the manual. On my K-r, I have to have a regular DA lens on the camera, set AF to AF.A, then put on the manual lens, and enable CiF in the menu. And the AF/MF button on the camera has to be turned to AF. And the lens must short the camera mount contacts (yours should do that, since it is A series and has metal mount with no insulating coating)
I already checked manual, it says:
1. this feature only works on Manual focus lenses (done)
2. set focus to AF.S (done)
3. disable AF.A (already disabled after mounting manual focus lens)
4. Set focus on position (done)
5. Press shutter fully! here the shutter releases right after I pressed it fully! and won't wait to anything happen
So error :/
What did u mean by "the lens must short the camera mount contacts" I think there might be a problem either with camera or lens mount
And I don't have another manual focus right now to test.
