Hello fellow pentaxians,
i got a Agfa 50mm f1.9 manual lens. It's a K-mount lens, and there is a trigger (not sure if that's the right word for it) for setting the aperture of the lens.
https://dl.dropboxusercontent.com/u/57656281/IMGP2328.jpg https://dl.dropboxusercontent.com/u/57656281/IMGP2327.jpg
The problem is, the camera doesn't detect that 'trigger' and i can't set the aperture value. With this lens attached the camera is working only in M and Av modes, and everything needs to be set manualy - i'm ok with that, as i don't require a fast decisions for making photos, i'm an amateur.
Is there any "cheat" or tweak i can do? I don't see any mechanical damage on the back (on the mount) side.
Oh, and there is not A (as for Auto) on the aperture ring
Sorry if i'm not stating the problem clear enough, hope You'll understand
