05-19-2013, 06:23 AM   #1
iht's Avatar
loose asahi pentax metal cap on 15/3.5?
I have a 15/3.5 that I love, but the original metal cap is dangling very loose theses days. I think it's the lens hood - I tried the cap in another 15/3.5 and it screws on that lens securely.
Any ideas on what I can do? Thanks in advance :-)
05-19-2013, 07:26 AM   #2
Moderator PEG Judges
Kerrowdown's Avatar
The metal lens cap is a push fit and your right not very secure, mine just falls off when I look at it.
Not quite sure what you screwing in and to where? as the lens hood is built in as a fixed part of the lens.
05-19-2013, 08:21 AM   #3
iht
iht's Avatar
QuoteOriginally posted by kerrowdown Quote
I guess I meant pushing into the built in hood :-)
But yeah, any ideas on maybe a replacement cap or something to hold the cap together?
05-19-2013, 08:29 AM   #4
Kerrowdown's Avatar
Aye, this is what I did with mine, get yourself some of that self adhesive velcro tape. Just use the soft fuzzy side, not the nylon loop side.
Stick a couple of bits in the inside sides of the cap to take up the slack, happy days.
05-19-2013, 09:27 PM   #5
This is a historic issue with slip-on lens caps. I have original equipment slip-on caps for my Takumars and and 77 limited as well as various other lenses I own, but these are kept in a drawer for safe keeping. For daily use, I have a collection of pinch-type caps.
05-20-2013, 03:15 AM   #6
The old push on caps, for Takumar, had a thin felt on the inner side to make the friction contact. This can wear. The solution would be to replace it with a new piece of felt, a bit thicker than the one that comes off, because the one that comes off is worn.
05-20-2013, 01:00 PM   #7
Kerrowdown's Avatar
QuoteOriginally posted by tim60 Quote
That's what I'm kinda suggesting with the velcro route as I couldn't get self adhesive felt at the time.
05-20-2013, 01:04 PM   #8
I had one recently where the original felt came loose, and seemed adequate. I fixed it with a contact adhesive like used in builidng. Therefore I presumed boring original felt with glue.
05-25-2013, 07:54 AM   #9
iht
iht's Avatar
Thanks for the replies guys.
Hmm...rather than adding an adhesive thingy onto the precious original cap, I'm wondering if anyone has a solution for an alternative cap? Like maybe a DIY solution or an alternative pinch cap?
05-25-2013, 05:29 PM   #10
Your lens has 49mm filter threads so something like this should work. You want the center-pinch type that does not have overhang.
Pentax O-LC49 49mm Front Lens Cap 31526
05-25-2013, 05:32 PM   #11
iht
iht's Avatar
Thanks, but I think you are mistaken. The A 15mm 3.5 definitely doesn't have a 49mm thread. Are you thinking of some other lens?
05-25-2013, 11:27 PM   #12
QuoteOriginally posted by iht Quote
Indeed it doesn't!!!
I thought you were using the DA 15/4. You may well have to craft something from plastic tubing.
05-26-2013, 12:43 AM   #13
The most likely would be uPVC pipe fittings from Bunnings. They do sell short lengths of pipe (around a metre - massively more than you need) and every size does have a plain cap available. You will need to measure OD of the front end of lens and find an ID of pipe that is just a bit bigger, and find a suitable felt to pack the gap with.
This should work out cheaper than buying an original s/h over eBay and paying postage on the very rare occasions that an unusual size cap becomes available. (Even common sizes like 49mm and 58mm are quite rare.)
05-26-2013, 07:38 AM   #14
iht
iht's Avatar
That sounds like a good idea! I'll give that a go. Thanks!
cap, k-mount, lens, metal, pentax lens, slr lens
For Sale - Sold: Genuine Asahi Pentax RARE 200mm f3.5 preset with metal hood cheekygeek Sold Items 3 01-15-2013 06:02 AM
How to straighten a bent metal Asahi Pentax lens cap? kcobain1992 Pentax SLR Lens Discussion 3 10-02-2011 01:44 AM
All times are GMT -7. The time now is 03:49 AM. | See also: NikonForums.com, part of our network of photo forums!
