well, every serious photographer out there want's the best for his shots, and i tell you this.. as i try to make it out as a photographer with my old gear and stuff, whay i see around here for serious photography is medium format..
and if pentax can deliever the medium format composition on a 35mm negative, that is without doubt the most atracting fearture of pentax cameras to professional photographers.
the fact you can get a medium format look on a 35mm negative makes it's impossible to make billboards and stuff like you do with medium format, but it's not impossible to make photography for magazines, web related magazines, etc etc...
so before discarding all this hypothesis, maybe you should look into them, because again...
haev the "odd focal lenghts" renamed to "the medium format standard" if a really good thing for pentax and ourselves, pentaxians that have been fighting against stupid feartures of other manufactures that in the end of the day, will improve nothing in your photography.
this? this medium format on 35mm look? now this would make lots of people to buy the limited or eevn change to pentax
more friends
do the maths, and don't forget the Apertuer must also be converted.
the first times i used medium format i was shocked i couldn't get a faster lens than 2.8 as i like thin DOF, but when i found what that a f2.8 on medium format is a 1.4 equivalente on 35mm film, my life was great again..
