I've got two copies of the Pentax-F SMC 35-70mm f3.5/4.5. I've noticed that their coatings have very different reflections, even when side-by-side under the same light (and regardless of how I hold or move them around). One is cool, tending toward blue, while the other is red/magenta (see attached image). Did SMC coatings vary this way over time (even on the same lens model)? Or did a previous owner over-clean and remove a layer (though I'd be surprised that ta layer could get removed so uniformly by an amateur cleaning). FYI, the "red" lens is about 40,000 later in its serial number, so I assume it is later production. Does anyone have any knowledge about this? Thanks much.
