05-25-2013, 10:59 AM   #16
The problem with the 16-45mm is finding one without barrel wobble. We've had some reports that the wobble can be fixed, but I haven't found any explanation of exactly how. The advantage of the 16-45mm vs. the 17-50mm, besides the obvious wide end, may be less focus field curvature at the wide end - it's a significant problem if you photograph any nearly flat subjects. Also there seem to be fewer autofocus accuracy/adjustment issues with the 16-45mm. On the other hand, f2.8 vs. f4 can be significant for some applications, and f2.8 definitely makes manual focus easier.
Paul
05-25-2013, 12:52 PM   #17
rparmar's Avatar
It should be noted that the "barrel wobble" is a cosmetic issue only. It doesn't affect the images. In terms of build, even the DA12-24 seems rather "cheap" for its price, unfortunately.
05-25-2013, 03:06 PM   #18
NitroDC's Avatar
If you're going to be doing a lot of shooting at 18mm, get a 15mm Limited. I was also considering buying a 16-45/17-70/17-50/etc to replace my kit lens but honestly? It's not really THAT bad. Sure, it might not be the best thing when a candid moment happens, but I guess if you want to go for the best you'd have to get a Sigma 17-50 or a DA* 16-50, or just go with an expensive prime. The 15mm never fails to amaze me in all aspects (except bokeh -- but who needs it on a 15mm wide lens???)
After buying the 15mm Limited, however, I've been considering the 18-135. Not only does it have better IQ than the kit lens, but it has more range, is more consistent, and has a great autofocus motor/system. I'd go for that since Pentax's 16-45 and 17-70 are both pretty old in comparison. You normally get more for your money with newer lens designs. And WR.
05-25-2013, 06:21 PM   #19
QuoteOriginally posted by rparmar Quote
I thought so too, until reading (and posting in) this thread:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/216555-advice-...ml#post2324267
and then retesting my own copy. The wobble definitely detracts from the performance of the 16-45mm.
Paul
05-26-2013, 12:36 PM   #20
rparmar's Avatar
Well, that's bad news since I imagine this applies to all the wobbly zooms, of which Pentax has a lot. The only time I shoot Pentax these days is for the DA12-24, so this makes me rethink even that.
da, k-mount, kit lens, lens, pentax lens, slr lens
Is it worth it to get a 16-45mm? carcrazy Pentax SLR Lens Discussion 22 05-13-2013 08:11 AM
Worth it to upgrade to FA 50mm f1.4? ChopperCharles Pentax SLR Lens Discussion 19 05-07-2012 09:03 AM
Is it worth upgrading from kit lens to Tamron 17-50? Mike M. Pentax SLR Lens Discussion 15 11-29-2011 08:57 PM
Is it worth trying to fix a kr or upgrade? Kricket Pentax K-r 13 07-15-2011 10:29 PM
is it worth it to upgrade to the K-r? raf02 Pentax K-r 6 11-03-2010 11:50 AM
All times are GMT -7. The time now is 05:50 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
