Originally posted by PBandJ If so, any tips? I'm traveling next week and want to give it a try.
Is the basic technique 4 photos across and 1 up and 1 down in the middle?
I won't get a second chance at any of the places we go.
I have done this hundreds of times with a circular fisheye, but now use a 10-17, which is diagonal fisheye. With any fisheye, use a tripod and a
pano head if you want to capture the "sphere" around you... and for a circular fisheye, you are right with the 4-around, one up, and one down if the ground is interesting. My 10-17@10mm requires 6-around...
Of course, where you are traveling you might not get a chance to use a tripod, either. In that case, with a little practice and a good pano stitching program, you can use a piece of string and a weight,
like this (called a "philopod"). The important part is that you rotate everything around the lens, not the camera body or your head.
