05-26-2013, 05:57 AM   #1
urssu's Avatar
SMC Pentax F 35-70mm F 3.5- 4.5 Focus Ring Problems (It' s jammed)
Good day,
As the title says I have a lens, the SMC Pentax F 35-70mm F 3.5- 4.5 and it has some problems focusing. At the four meter focus distance it has a jam. It just stops. You have to force it to pass on every other side (lower then 4m or above) . Did anybody else have this problem? What are the solutions? Should I send it to a repair `master` ?
Thank you!
05-26-2013, 09:13 AM   #2
Jean Poitiers's Avatar
That's a nice compact zoom ... I have it and use it quite often ... no problems with my copy.
It might be better to buy another one if the repair estimate/bill is too steep ... good luck, J
05-26-2013, 09:19 AM   #3
It's a 40 / $60 lens. Will almost certainly cost more to repair than to replace. Can you live with the problem?
05-26-2013, 09:31 AM   #4
Docrwm's Avatar
I have one too and it's been fine. It might be tougher to get another one in Romania but they do come up here occasionally for $40-60.
05-26-2013, 12:41 PM   #5
urssu's Avatar
Good day,
Thank you all for the replies. Basically you are telling me to buy another one...
05-26-2013, 01:12 PM   #6
Try this, it's not as scary as it looks.
https://www.facebook.com/media/set/?set=a.10150093044109265.271429.755984264
I have opened (and put together) few of the Penax-F zooms. The are all similar inside. Both time I needed to fix the zoom movement. Follow the link for detail
06-29-2013, 01:36 AM   #7
mtux's Avatar
I have a same problem, but mine is stuck at somewhere between 4 and infinity, and does not go less that there. I can just turn the ring to infinity and turn it back there, while auto focusing it just goes to infinity and back there, and stop.
Did you found a solution!? I'm ready to open the lens and look through it, if I know what should I look for and what can I do for it!?
Any advice? (other than buying another one )
06-30-2013, 08:55 AM   #8
urssu's Avatar
QuoteOriginally posted by mtux Quote
Good day,
Personally I didn' t repair it. For me to repair it, would cost another lens (if I can get it again at its right price, that is low) .
Instead I bought a 35mm F2.4- very nice colors but I think mine has backfocus. Will `attack` this problem later.
All in all, if it' s cheaper to repair - repair it if not, buy another one.
All the best!
focus, k-mount, pentax, pentax f 35-70mm, pentax lens, slr lens, smc, smc pentax
Pentax-F 35-70mm f/3.5-4.5 samples Nick Siebers Lens Sample Photo Archive 17 12-13-2014 11:17 AM
Wanted - Acquired: SMC Pentax-F 35-70mm F3.5-4.5 / FA 35-80mm F4-5.6 telly0050 Sold Items 5 02-16-2012 01:09 PM
For Sale - Sold: Pentax SMC-F 50mm F1.7 AND SMC-F 35-70mm F3.5-4.5 harryc Sold Items 12 11-21-2011 08:42 PM
For Sale - Sold: Pentax SMC-F 35-70mm f/3.5-4.5 Macro Zoom Lens wallyb Sold Items 3 10-14-2009 02:16 PM
All times are GMT -7. The time now is 10:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
