05-30-2013, 08:57 PM   #1
Asahi Pentax SMC 50mm F1.2 Lens partlally machined to easily adapt to Canon EOS
Would you get one and what is a good price to you?
What are the shortcoming of it being modified for canon and also if this is usable for pentax body?
Thanks
05-31-2013, 12:56 AM   #2
If its somehow grinded down to get to EOS flange distance, then forget it.
It also hints at the kind of attitude the seller/converter had w/ lenses. (Ie. Heck care)
You may have inaccurate focus at infinity too, depending on care during the grinding down (On EOS mount)
You probably can only focus near on K-mount.
Typical conversion is just to remove the lever guard (just 3 screws),
Cut off the aperture lever. (Unless one finds the lever mechanism from another spoilt lens to use)
Use a k-eos adapter.
This way, the lens is still usable on K-mount, but the aperture stops down when you change f-stop.
You need to try out the lens for sure.
05-31-2013, 04:24 AM   #3
This is the picture the seller send me and this is what he told me,There is only cylindrical rear lens barrel cut off not to touch the reflex mirror
05-31-2013, 04:47 AM   #4
Looks ok.
Seems like lever guard was grind down and lever cut off.
It works just like a takumar lens.
05-31-2013, 04:53 AM   #5
Clavius's Avatar
Without the aperture leaver it will even have an advantage on your Pentax. Without it, you can switch to AV mode and it will constantly calculate the appropriate shutter speed, without you having to use the green button all the time.
05-31-2013, 05:00 AM   #6
robbiec's Avatar
Butchered! Canon fu$%ers. Hate it when I see stuff like this.
05-31-2013, 05:37 AM   #7
Clavius's Avatar
QuoteOriginally posted by robbiec Quote
What do you hate? When Pentax fails to provide a camera format for which your lens was designed and the other brands don't? There simply is no other choice.
05-31-2013, 06:26 AM   #8
RobA_Oz's Avatar
QuoteOriginally posted by Clavius Quote
It would have been far easier to simply take off the mounting flange and remove the lever. This modification is irreversible without obtaining another aperture lever, so it's unnecessary butchery. I despair at this sort of thing, rather than get angry.
05-31-2013, 08:47 AM   #9
gofour3's Avatar
QuoteOriginally posted by RobA_Oz Quote
I agree it should be a crime to butcher a Pentax lens. I’d skip buying this one, there are lots of Pentax 50/1.2s for sale that are intact. I hope the seller gets stuck with it!
Phil.
05-31-2013, 01:10 PM   #10
robbiec's Avatar
Bollocks! The vast majority doing this are not because Pentax won't deliver a format that the lens was originally designed for but because 1: A50 f/1.2 is better optically than the equivalent EF lens and 2: because it is half the price!
As Phil says, walk away and get a properly functioning A series.
05-31-2013, 03:14 PM   #11
Thanks guys,I will reconsider about it but the asking price is 305usd with shipping to my country..that's why i am tempted as a normal K50 f1.2 would cost easily at least 400 plus to 500 usd?
05-31-2013, 08:47 PM   #12
Otis Memorial Pentaxian
The usual solution is to grind the mirror on the Canon. This issue is long-standing (dates back to the earlier FD mount), is not limited to Pentax glass, and is well known in Canon circles. Most Canon owners who shoot non-Canon glass are sensitive to the value and heritage of the lenses they use and choose to respect the lens over the body.
05-31-2013, 08:49 PM   #13
QuoteOriginally posted by iittoo Quote
Walk away. The price is too, too high for damaged goods.
06-01-2013, 07:21 AM   #14
Not all lever mechanisms cab be removed.
Many are fixed to the aperture moving mechanism.
Looking at it objectively, the lens is functional in most ways other than no open metering and dark viewfinder for f4 and higher usage.
06-01-2013, 10:14 AM   #15
PEG Moderator
Kerrowdown's Avatar
I'm sure the wait for a "virgin" 1.2 would be worth the price in the end, recommend the A series.
50mm f1.2 lens, asahi pentax smc, canon, k-mount, pentax, pentax lens, pentax smc 50mm, slr lens, smc 50mm f1.2
Pentax smc 50mm f1.7 , unable to turn to f1.7 Rob Dean Pentax SLR Lens Discussion 12 05-07-2013 03:12 AM
SMC PENTAX-M 1:1.4 50mm ASAHI OPT..Is it good lens to buy please suggest... samysarena Pentax SLR Lens Discussion 19 04-12-2013 01:22 AM
Pentax SMC 50mm F1.2 on a Canon Chaos_Realm Pentax SLR Lens Discussion 14 11-25-2012 05:44 PM
Pentax PK lens to Canon EOS adapter NRV Shooter Pentax SLR Lens Discussion 6 11-20-2011 04:35 AM
Asahi Pentax Spotmatic SLR lens adapter for Canon DSLR EOS? emmatrim Pentax SLR Lens Discussion 6 03-28-2010 12:43 PM
All times are GMT -7. The time now is 08:22 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
