06-05-2013, 04:52 PM   #1
Soligor manual focus zoom lens
I own a Pentax Kr and a K200D. I recently found a older Soligor manual focus zoom lens at a swap meet that fits Pentax. However, I tried to mount it on both cameras with no luck! Is there a adapter I need to buy in order to use this lens?
The lens looks new and was well taken care of. The lens is 28- 200 mm f3.5 - 22 and has this on the lens mount: P/K -A R- P/K Any ideas??
06-05-2013, 05:22 PM   #2
VisualDarkness's Avatar
Can you post a pic?
06-05-2013, 05:32 PM   #3
The R-P/K marking indicates that it could have the Ricoh pin that can cause the lens to get stuck on the camera, but that won't cause it not to mount.
There is likely an oversized aperture lever shield blocking it from being mounted on the camera, this interferes with the PZ/SDM contacts on the newer bodies.
06-05-2013, 05:34 PM   #4
THoog's Avatar
Soligor lenses frequently have an extended "shield" for the aperture arm on the mount. The shield bumps into the body of the camera around the SDM contacts and prevents it from mounting. I have two like that - I cut away the extra shield, and they work fine. (Removed metal marked red in the photo - Pentax M on left, modified Soligor on right)
To alter the mount:
1) Remove mount plate from lens (probably just four screws)
2) Cut away excess shield with Dremel cutting wheel (marked in red)
3) Be sure to remove all dust
4) Reinstall mount plate on lens
5) Blacken any bright metal with a Sharpie pen to prevent reflections.
06-24-2013, 05:42 PM   #5
Thanx to THoog for your help with my Soligor zoom lens. I did what you suggested and I removed the excess shield from the mount plate and now the lens mounts perfectly!!!!!!!!!!! Thank you again.
focus, k-mount, lens, p/k, pentax, pentax lens, slr lens, soligor
K-5 Manual Lens Front Focus & Focus Beep woes fixed kneonx Pentax K-5 14 04-12-2014 03:47 PM
Manual Focus w/ 18-135 zoom? Javaslinger Troubleshooting and Beginner Help 2 02-26-2013 08:06 AM
10 Reasons why manual focus primes are better than those new auto focus zoom lenses JoepLX3 Pentax SLR Lens Discussion 188 07-25-2012 03:28 PM
manual focus tele zoom jkglogau Pentax SLR Lens Discussion 7 03-06-2009 09:02 AM
All times are GMT -7. The time now is 06:57 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
