06-07-2013, 04:43 PM   #1
troika's Avatar
EXIF / Focal Length / DA 18-135 WR
I've been trying to shoot with my zoom at specific focal lengths to understand those FLs and consider whether primes in those lengths would be useful or not. But, but I've noticed that the focal length in my EXIF data never matches where I had it set exactly. If I'm going 55m, for example, I'm not surprised if it's off, but I just shot some at 24, which is clearly marked on the zoom and it shows as 21mm in the EXIF. I've done that with other lengths as well with similar results.
Which is more likely to be accurate? The markings on the lens or the EXIF data?
06-07-2013, 05:16 PM   #2
troika's Avatar
It occurred to me that I have one prime in a focal length that is printed on the register of my zoom, so set up my tripod, focused on a birdfeeder and took a shot with my M100/f4 Macro and one with my Zoom @ 100mm. They are both below.
DA 18-135 WR @ 100mm
M100/f4 Macro
Interestingly enough, the EXIF data does indicate 100mm, I didn't think it would, but I'm not sure that they look the same in terms of magnification. What do you think?
<EDIT> the M100 is definitely a tighter crop. Look at the windows on the house and the branch on the tree. It's not much, but it's as different, probably as the 24mm photo that I tried to take that showed as a 21mm photo in the EXIF data.
So, that would suggest....wait, what does this mean?
06-07-2013, 05:23 PM   #3
RonakG's Avatar
To me both look same in terms of magnification.
06-07-2013, 05:55 PM   #4
jatrax's Avatar
Camera moved to the left on the M 100mm shot. More tree is showing on the left and less window on the right.
06-07-2013, 06:44 PM   #5
troika's Avatar
Yeah, I think you're right. I looked more critically after the first response.
So, the consensus is that 100mm is 100mm and if my EXIF data suggests that the focal length is not where I thought I was setting it, it's probably the imprecision of the register on the zoom, the EXIF data is correct?
06-07-2013, 07:16 PM   #6
jcdoss's Avatar
Also, focal length is not an absolute measure of field of view.
06-07-2013, 07:25 PM   #7
jatrax's Avatar
QuoteOriginally posted by troika Quote
Well, it looks correct at 100mm. I'm not sure how the lens tells the camera what the focal length is, but I can think that it might have a little slop in it or might not be 100% accurate, or it might only report in 'steps'. Not saying it is or isn't just that all this test seems to indicate is that at 100mm it is fine.
A definitive test would involve a prime lens of each of the marked focal lengths and using a target that is easier to measure with. And a totally locked down tripod.
data, exif, k-mount, length, lengths, pentax lens, slr lens
EXIF focal length for A lenses on 645D? jwoodland Pentax Medium Format 9 11-19-2016 08:53 PM
Thematic Outdoors, in bad weather, using your DA WR zooms: 18-55, 18-135, 50-200. MD Optofonik Mini-Challenges, Games, and Photo Stories 3 05-11-2013 05:59 PM
For Sale - Sold: Pentax 18-135 DA WR, 50-135 f2.8 DA* biphers Sold Items 14 12-16-2012 09:01 PM
Focal Length from EXIF metalfab Pentax SLR Lens Discussion 3 03-27-2008 06:13 AM
All times are GMT -7. The time now is 10:28 AM. | See also: NikonForums.com, part of our network of photo forums!
