Originally posted by normhead Did you even read the test reports?
I did and -- on top of it -- I'm aware that the 18-250 figures were obtained with a K10D while the 18-135 figures were obtained with a K-5.
As a result, you cannot compare the numbers. Before you start converting them based on sensor resolution difference, know that Klaus sharpens the images and it is very likely that the sharpening levels are not the same.
Hence, your comparison of the two lenses based on the PZ numbers is invalid.
Note that Klaus says
"The Pentax lens is actually very good to even excellent in the image center but the borders/corners suffer from massive field curvature at the wide end and plain sofness at tele settings. This is certainly no issue for portraits and such but you don't really want use this lens for architecture or landscape photography here. This is also in so far surprising because the (cheaper) Pentax SMC-DA 18-250mm f/3.5-6.3 (a Tamron design) was actually very usable here. "
What can be gathered from the PZ figures is that the 18-250 has a much more balanced performance while the 18-135 loses performance outside the centre rather quickly and dramatically.
Klaus had the 18-135 checked by Pentax Germany and it was found to be "
within factory specifications". How dumb would they have to be to not acknowledge an issue or lend him another copy?
To be clear: I've seen very nice images from the 18-135 and I trust that many owners enjoy it a lot. But I doubt that it beats the 18-250 optically. On the other hand, I don't really care personally as I'm much more interested in high quality prime lenses.
