06-17-2013, 09:23 PM   #1
Hood or No Hood?
I have a Pentax F50 f1.7 that I have a metal screw mount lens hood that fits it perfectly.
Discussion I would like to see is the pros and cons of using a hood for this kind of lens. Does it 'really' help anything? Or is it just taking up space?
06-17-2013, 09:25 PM   #2
JinDesu's Avatar
Pro:
Increases contrast when shooting wide open
Can help protect the front element from things swinging into it
Reduces flare
Cons:
None, unless you are really that picky.
06-17-2013, 09:32 PM   #3
I think you will find that most of the veteran users on this site are decidedly pro-hood.
06-17-2013, 09:37 PM   #4
scratchpaddy's Avatar
QuoteOriginally posted by alamo5000 Quote
That's the worst it can do. It can't hurt. I use those $2 collapsible rubber ones you can find on the 'bay. You'd be surprised how much they help, especially on old lenses with feeble coatings.
I don't think I've ever seen an anti-hood opinion.
06-17-2013, 09:38 PM   #5
I've been using the hood without fail. It normally stays on the lens, but I got to playing with the lens and began to question my choice to do so.
Why? Just because i was thinking about it
06-17-2013, 09:44 PM   #6
Docrwm's Avatar
Enhances contrast on nearly every lens, which is in-and-of itself sufficient to justify using it (but it does more too).
06-17-2013, 09:47 PM   #7
Sandy Hancock's Avatar
Just do it.
06-17-2013, 10:11 PM   #8
geomez's Avatar
There was a conversation on the forum a few days ago about this very same question about the very same lens. Someone recommended a 49mm to 28mm step-down filter as an option instead of a hood. Seeing how I've recently acquired that lens, I'm gonna try out the step-down filter.
49mm to 28mm Step Down Filter Ring Adapter 49 28 | eBay
06-17-2013, 10:27 PM   #9
kiwi_jono's Avatar
Agree with previous comments. The hood nearly always helps and with some lenses its helps a lot. For example my Tokina AT-X Pro 28-70 f2.8 is almost transformed with a hood - so much better contrast (I have comparative shots to prove it).
I can think of one case not use a hood and thats when you want a discreet configuration using a compact camera configuration with a pancake like a DA 40 (which is probably still pretty good with out a hood - at least indoors).
Maybe if you are taking just the occasional quick shot. Unfortunately many lenses / hood combinations don't allow you to put a lens cap on with hood fitted.
06-17-2013, 11:07 PM   #10
sam-joseph's Avatar
Bring back the built-in hood I say! My Tak 135mm and the M-200mm I had, both had built-in hoods.
I never once left their hoods at home.
Regards
06-18-2013, 04:56 AM   #11
JimmyDranox's Avatar
Beyond what has been previously said, a hood is the best protection for the lens front element. And a hood is cheaper than a good filter. So, I always keep the hood on every lens. I know it takes up more room, but it's safer and faster. Especially since I always forget to put the lenscap.
06-18-2013, 05:06 AM   #12
Pablom's Avatar
Unless you want flare, go for the hood
06-18-2013, 05:23 AM   #13
A hood improves IQ. A filter, no matter how good, degrades IQ.
06-18-2013, 05:28 AM   #14
You gotta go with the hood...unless you are deliberately shooting a low contrast shot or want the effect of a little flare (or a lot of flare depending on the lens).
06-18-2013, 06:19 AM   #15
stormtech's Avatar
Simply well said.
hood, k-mount, lens, pentax lens, slr lens
LCD Hood or Shade? ibkc Pentax K-01 29 03-03-2013 12:13 PM
For Sale - Sold: Well-respected Tamron 60-300mm SP (no Adaptall mount) with orig. hood cheekygeek Sold Items 7 12-06-2012 09:56 PM
Hood or no hood? woonona_butch Troubleshooting and Beginner Help 23 11-11-2010 06:30 AM
For Sale - Sold: Pentax 18-55mm lens hood with box (no lens, just hood and box) drabina Sold Items 3 09-13-2008 06:21 PM
All times are GMT -7. The time now is 07:24 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
