06-18-2013, 12:23 PM   #1
PBandJ's Avatar
Size for 2d hood using step up ring?
Hi all,
I have a sigma 17-70 with the original hood. It has a 72mm filter ring.
My ND filters and CPL are 77mm. I can't use the hood with the filters.
Would a 77mm rubber hood work? I prefer plastic or metal.. [if I can do that ..which?]
Thx
06-18-2013, 12:25 PM   #2
mrNewt's Avatar
yea it should... as long the step-up ring is from 72mm to 77mm and the hood is built for 77mm thread .
It doesn't matter if is rubber/plastic/metal
Just keep in mind the angle at witch the hood opens - the wrong hood will give vignette at and towards the 17mm.
A hood with a similar opening angle with the original one should be safe enough.
Hoods galore: http://www.ebay.ca/sch/i.html?_trksid=p5197.m570.l1313.TR0.TRC0&_nkw=wide+an...at=0&_from=R40
06-18-2013, 12:27 PM   #3
PBandJ's Avatar
QuoteOriginally posted by mrNewt Quote
Yes the step up ring is 72-77. Thanks, I will order one from the Far East
77mm, filters, hood, k-mount, pentax lens, slr lens
step down ring or step up ring ? dh4412 Troubleshooting and Beginner Help 5 04-14-2012 04:39 AM
step up/down filters for Digi-slave LR3200 & Flashpoint VL-48 Macro Ring Flash ? eva2000 Flashes, Lighting, and Studio 8 06-08-2010 02:27 AM
step-up ring vs different size filters math guy Pentax SLR Lens Discussion 8 04-21-2010 09:43 PM
Step up or Step down ring for FA 50mm f1.4 and filters. Xcom Pentax Camera and Field Accessories 4 05-11-2009 11:56 PM
All times are GMT -7. The time now is 12:42 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
