Originally posted by John Poirier Given that the images were made with inconsistent framing, at different focal lengths and different apertures, with unstated parameters such as whether a tripod was used, the point of the comparison escapes me.
According to the EXIF data, A was made with the 43 at f/2.8 1/2000. B was at 42.5mm, which would be the kit lens, f/8 1/250. C would have to be the 50-135 at 95mm, f/5.6, 1/500.
Under the circumstances any comparative comments about bokeh are meaningless.
I did not cheat and look at the EXIF.
While the framing is inconsistent, the main subject is more or less the same size in each photo. Therefore, the relative size of the background objects can give you a clue about focal length. You can tell that one of the shots is at significantly longer FL than the other two. Since we know the 3 candidates don't overlap by any significant amount, and we know the difference in FL between the photos is large, it is simple logic to conclude that the only choice for the long FL shot is the 50-135. We can also tell that the other two shots are close to the same FL, again based on the relative sizes of background objects. Therefore, we know that the kit lens shot is near 43mm, and therefore has an aperture above 4.5. Of the other two, the aperture value of picture A is obviously larger than B, and also obviously larger than F4.5. We can therefore conclude that A is the 43 Ltd, leaving B as the kit lens.
It really was very easy to figure out.
