06-24-2013, 08:58 PM   #1
CMS Houston's Avatar
GND Filters for 15mm Ltd and 40mm Ltd - Advice Please!
I own both the 15mm Ltd and 40mm Ltd. I am contemplating the purchase a soft GND and reverse GND filter, but I am concerned about compatibility given the small iris of both lenses - especially when stopped down. Does anyone have any experience using GND filters on either of these lenses? Your advice would be much appreciated.
06-24-2013, 09:22 PM   #2
Digitalis's Avatar
You shouldn't have a problem - I regularly use large square GND filter systems with the DA15mm f/4 without issue.
06-25-2013, 04:00 AM   #3
TZH
TZH's Avatar
You shouldn't a problem - I regularly use large square GND filter systems with the DA15mm f/4 without issue.
Will Cokin P series done the job? Or a step-up / blank filter ring to avoid the build-in hood?
06-25-2013, 08:35 AM   #4
Digitalis's Avatar
QuoteOriginally posted by TZH Quote
Will Cokin P series done the job? Or a step-up / blank filter ring to avoid the build-in filter?
A blank filter may be needed to clear the built in hood of the DA15mm f/4, but the DA40mm f/2.8 should be fine.
06-25-2013, 09:27 AM   #5
In my experience Cokin P vignettes on the DA 15, even with the wide angle holder. My Lee system, with with the wide angle adapter, vignettes ever so slightly, but that's probably because the "spacer" ring I use is a tad too thick.
06-25-2013, 09:57 AM   #6
Digitalis's Avatar
QuoteOriginally posted by northcoastgreg Quote
I didn't know that, I have always used a thin filter ring when I use the Lee system with the DA15mm f/4.
06-25-2013, 10:12 AM   #7
Much thanks for the response!
15mm ltd, advice, filters, gnd, gnd filters, k-mount, ltd, ltd and 40mm, pentax lens, slr lens
Please recommend a filter for DA 15mm ltd pentaxfang Pentax SLR Lens Discussion 10 10-16-2011 09:47 PM
DA 15mm LTD and GND Filters trublubiker Pentax SLR Lens Discussion 5 10-24-2010 02:42 AM
For Sale - Sold: Brand New in Box: DA 15mm ltd, DA 40mm ltd, DA 17-70mm, DA 18-55mm WR chemxaj Sold Items 8 12-01-2009 02:16 PM
Short Tela (40mm Ltd.) vs. Wide Angle (15mm Ltd.) CanadIan Post Your Photos! 12 09-20-2009 10:51 PM
All times are GMT -7. The time now is 06:16 PM. | See also: NikonForums.com, part of our network of photo forums!
