06-25-2013, 08:35 PM   #1
modifying a lens with no A/M switch
I just got a Yashica Yashinon DS-M 50/1.7 in beautiful condition ($8 at local thrift store). However, it does not have the Auto/Manual switch of the DX 50/1.7 (and others). I read that I would need to modify it to make it full manual. If so, how can i do this in a reversible (non-destructive) way, and with the least amount of disassembly? Any input always welcome. Thanks.
06-25-2013, 08:47 PM   #2
aleonx3's Avatar
you can use something (I just cut a small piece of plastic from a 12-gauge wire) as a spacer and insert it in the spring-mechanism to keep the PIN staying up all the time. You can access the spring-mechanism by removing the rear glass element with a lens spanner. This way, the lens will be in M mode permanently until you remove the spacer again (not that you would want to do that).
06-26-2013, 02:12 AM   #3
Lowell Goudge's Avatar
here is a shot of the modification i did to a tameron adaptall M42 mount
i did the same modification to my zenitar 16mm fisheye
i use a small section of the plastic ink refill from a ball point pen. just the right size
k-mount, pentax lens, slr lens, switch
what will happen to a lens with no front name plate? mingkoy Pentax SLR Lens Discussion 16 05-04-2013 05:13 AM
Modifying a Soligor C/D7 to get a focuser for special lenses sindbad1 Pentax Camera and Field Accessories 2 04-01-2012 01:07 AM
Modifying a Pentax lens SimonMW Pentax SLR Lens Discussion 10 12-13-2010 05:26 PM
Help: Using Flash with M Lenses (no A position) Doanh Troubleshooting and Beginner Help 4 01-05-2010 01:11 PM
My K200D is on the fritz (a.k.a. no, I'm just a goober) khardur Pentax DSLR Discussion 2 05-22-2008 03:45 PM
All times are GMT -7. The time now is 06:12 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
