06-27-2013, 08:01 AM   #16
How about pinhole lenses?
They don't even have a single element!
06-27-2013, 09:08 AM   #17
The mount cover lens on Q is the only one like that from pentax
06-27-2013, 09:32 AM   #18
Not a Number's Avatar
Holga "pinhole" lenses have a plastic lens:
HOLGA HL-P Lens for PENTAX DSLR SLR K-5 K-r K-x K-m K-7 K20D K110D LOMO | eBay
06-27-2013, 09:48 AM   #19
According to its "specifiation" (sic!),
that's an optical lens that needs focusing, not a pinhole.
06-27-2013, 04:45 PM   #20
My bad. However the Holga HL-P has only a single element.
06-27-2013, 06:23 PM   #21
Right, it certainly answers OP's question.
06-28-2013, 06:39 AM   #22
konstruktor DIY kit from lomography it lens got 1 element you can screw it into your K mount with M42 adapter
06-28-2013, 08:03 AM   #23
QuoteOriginally posted by ignmar Quote
Well.. I am building my own single element lens! I had a cheap Kalimar, whose mount was not compatible with Pentax. I am using its front element and the helicoid mechanism to build my own manual focus lens with no aperture control (always wide open). Looks like the results are almost as expected but due to lack of a proper camera mount, it is a little hard to use. I am trying to figure out how to attach a K-mount!
06-28-2013, 08:20 AM   #24
Na Horuk's Avatar
There are many meniscus, body cap and pin-hole type lenses out there, don't know if you would count them as "single element" and don't know if they actually are just a hole or if they have some kind of lens in there. And some might need adapters. But I don't have any list on hand and Adam is the authority on actual Pentax brand stuff
06-28-2013, 08:24 AM   #25
QuoteOriginally posted by TropicalMonkey Quote
if you need just a mount that quite easy just buy a cheap body cap and cut out the middle piece then glue it with hot glue there will be fit just fine.
06-28-2013, 08:43 AM   #26
Very good idea! I have several body-caps lying around.
06-28-2013, 08:46 AM   #27
Not entirely irrelevant to this thread...
..a Fraunhofer achromatic doublet (two elements in one group) brings red and blue light to the same focus.
500mm FL f/5 at about 80 feet and 30 feet as I recall. Generally the fewer the elements the better the contrast all else being equal but it sometimes can take a lot of PP to get a achromat file to look right.
This scope cost 100 bucks new.
06-28-2013, 09:20 AM   #28
Wow! Nice shots!!!
QuoteOriginally posted by wildman Quote
Minimal (or lack of) internal reflections and minimum number of elements in the "signal" path.
Can you explain that, please?
Edit: I can't stop looking at those images! Did you do any post-processing at all?
BTW, what lens/scope is that?
06-28-2013, 09:45 AM   #29
scratchpaddy's Avatar
Inspired by this thread, I did something like that yesterday with the front element of a fungus-infected JCPenney zoom. I just used toilet paper tubes and tape. You can see the results here:
https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/229186-tp-special.html
One sample:
06-28-2013, 09:59 AM   #30
Is that the reason to have more than one lens -- to focus both ends of the spectrum to the same point? The lens material has to be different on those two lenses then.
I also took several shots but all indoor, so I didn't notice the chromatic abberation, it all looked "dreamy"!!
element, k-mount, pentax lens, slr lens
Are there any tiny, good, cheap 50-ish lens for the Q GibbyTheMole Pentax Q 3 01-23-2013 05:01 PM
Tessar Type 4-element lens in K-mount? Hamster Pentax SLR Lens Discussion 12 06-19-2012 03:55 PM
New to the forum and looking for a 49mm reversing k mount, any for sale out there? kd1 Welcomes and Introductions 5 02-04-2012 06:04 PM
Are there any F2.8 Macro lenses that are STILL F2.8 at macro distances? Unsinkable II Pentax SLR Lens Discussion 58 10-03-2010 05:25 PM
Are there any cheap AF primes? Steve Beswick Pentax SLR Lens Discussion 14 10-23-2009 01:54 AM
All times are GMT -7. The time now is 05:26 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
