01-31-2007, 05:57 AM   #31
Piotr's Avatar
QuoteOriginally posted by roy Quote
unless you set it up
amazing, great shot, congratulation
01-31-2007, 05:10 PM   #32
rfortson's Avatar
Hey Mo,
I think I saw this on KEH but it mentioned a "manual diaphragm". What does that mean and how is it different from manual aperture?
01-31-2007, 06:13 PM   #33
"Manual diaphragm" simply means that there's no stop-down lever on the mount, and hence the aperture of the lens will always be what it is set to on the [huge] aperture ring. This is obviously because the aperture is situated very far away from the camera.
On DSLRs, this elimitantes the use of the green button, so it can be seen as good
01-31-2007, 06:29 PM   #34
rfortson's Avatar
QuoteOriginally posted by Mo Quote
Thanks Mo. Then how do you set exposure if you can't stop down?
01-31-2007, 06:40 PM   #35
The aperture is permanently stopped down to whatever the ring is set to as opposed to being kept wide-open when mounted on the camera.
The fact that most M and K lenses have an auto diaphragm actually makes them harder to use. This is because you have to stop down first to measure the light, unlike on man.diaphragm lenses.
Basically, the point is that you can use P mode with man. diaphragm lenses.
02-01-2007, 09:14 AM   #36
rfortson's Avatar
Interesting. So I guess the down side would be that if you're shooting stopped down, the view in the viewfinder could be dim?
02-01-2007, 02:31 PM   #37
Yeah, that would be the only downside
02-01-2007, 03:36 PM   #38
roy
roy's Avatar
QuoteOriginally posted by rfortson Quote
i just use Av mode. focus at f4.5 and close down to get the shot.
what's really weird to me is the aperture adj is further away from the camera than the focus adj. backwards from other lenses.. i'm still trying to focus with the aperture ring.. stopping down isn't all that necessary because these lenses are tack sharp at f4.5 and unbelievable at f8-16.
02-01-2007, 03:59 PM   #39
im insanly jealous..you do know that right? :P
02-26-2007, 04:03 PM   #40
Just picked up mine this winter, a 500mm Takumar M42, non SMC. So far a
wonder lens. If anyone is curious I had to do some repair work on this. The
work required partial dissasembly. I have some pointers if anyone else needs
help and some pix of the unit being disassembled.
I have seen notes on the web that these lenses are interchangeable with
the 645 system with their removable rear barrel, and that Pentax had a
terrestrial eyepiece for these also. So far I have found no details on this. Any
suggestions out there?
02-26-2007, 05:43 PM   #41
Ole
Ole's Avatar
Would like your disassembly instructions
QuoteOriginally posted by lzzap Quote
We need to do some work on a Takumar, where the auto/manual aperture button is stuck.
Your disassembly instructions could come in handy.
Thanks in advance,
02-26-2007, 09:50 PM   #42
Any chance one could use a monopod with one of these bad boys? I'm half-looking at picking one up someday, but have yet to migrate to tripod-based shooting.
02-27-2007, 01:36 AM   #43
Arjay Bee's Avatar
Lens Repair
Ole - what Takumar are you working on?
This website is worth a read:
PENTAX MANUALS
For if you want to go the whole hog: (no connection to me)
eBay: Pentax Takumar & Super Takumar Lens Repair Manual (item 320076114552 end time Mar-27-07 02:40:51 PDT)
Another site:
Manual Focus Forum / Takumar 300mm problems
This forum has a heap of info on scores of other lenses as well.
This is my favourite site and I have spent hours here:
Topics - The Classic Camera Repair Forum
Almost leads you to think you can do everything yourself....
Are you sure there isn't a little pin that you need to actuate by mounting the camera on a body to get that button to slide. Or if the lens is mounted that the pin is not protruding far enough to be actuated?
02-27-2007, 10:38 AM   #44
FotoPete's Avatar
Haha The biggest threat to average joe shutterbugs worldwide..
Lenses of Mass Dimensions.
Hey has anyone tried the Phoenix 500mm f8. The refractor one.
02-27-2007, 12:15 PM   #45
I have the Pentax 400-600mm mirror lens, and although it's compact and fairly sharp, it's very hard to keep steady (even on a tripod) and can therefore not replace a regular tele.
500mm, k-mount, pentax lens, slr lens
Need lens hood for Sigma 170-500mm...same as 50-500mm and 150-500mm? Help please! Edgar_in_Indy Pentax SLR Lens Discussion 14 01-11-2022 08:50 AM
Sigma 50-500mm Versus Five Star 500mm Nowhere Matt Pentax SLR Lens Discussion 7 02-26-2010 12:56 PM
Sigma 50-500mm vs 150-500mm or Pentax DA 55-300mm with 1.4 TC? mikejustice Pentax SLR Lens Discussion 20 12-18-2009 07:59 PM
Wanted - Acquired: 100-400mm, 100-500mm, 150-500mm or similar K-mount lens GibbyTheMole Sold Items 8 12-03-2009 11:52 AM
All times are GMT -7. The time now is 01:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
