07-09-2013, 01:36 PM   #1
question about Super-Tak 150/4
I just bought a mint, almost new condition Super Tak 150/4 from E-pray. This one should be the later Super-tak with the Auto/Man labelling next to the switch. It came with the original case and hood (no caps). However there are two minor issues that I am wondering about. First, the front ring with the lens info on it is slightly loose. Very slightly, in that it has probably less than 1 mm of movement to it, side-to-side movement, not twist. How can i tighten that, and do i even need to. The lens doesn't move at all, just this front piece.
My next issue is that that on that same ring, where there should be threads to hold a filter or the lens hood, the end is almost flush and there are no exposed threads. So I can't attach the lens hood.... The lens hood is an original Asahi Pentax hood marked "Takumar 1:35 135mm 1:4 150mm 1:5.6 200mm" and has a 49 mm ring size.
Please advise me wise ones...
07-09-2013, 02:20 PM   #2
Hi Toukan
Sounds like the filter ring is loose. What you need to do is remove the trim ring with the writing on it using a suitably sized rubber gripper/friction tool. A bath plug or a rubber stopper of the right size can be used for this and it sounds like it is already mostly unscrewed, hence no threads for filters. A little lighter fluid applied with a toothpick on the area where the filter threads should be may help. When you remove the trim piece you will find three small crosshead screws between the inner lens barrel and the outer lens body. Look closely directly from the front of the lens in the exposed groove. A small cross tip screwdriver with a longish tip can then be used to tighten the screws. Replace the trim piece using the rubber tool making sure to screw it all the way in to expose the filter threads and you should be fine. Good luck
front, hood, k-mount, lens, mm, movement, pentax lens, slr lens, super-tak, threads
For Sale - Sold: Super Tak 50 1.4, Super Tak 35 3.5 (Both Need Repair) joe.penn Sold Items 1 02-14-2012 07:14 PM
For Sale - Sold: Super Tak 200mm f/4 | Super Tak 135mm f/3.5 joe.penn Sold Items 6 10-20-2011 01:57 PM
For Sale - Sold: SMC Tak 150mm/4, SMC Tak 135mm/3.5, Super Tak 55mm/2 and extras pdxbmw Sold Items 8 09-10-2009 10:54 AM
Question About Super Takumar 50/1.4 zx-m Pentax SLR Lens Discussion 19 03-06-2009 05:40 PM
All times are GMT -7. The time now is 08:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
