07-11-2013, 01:33 AM   #1
Trudger1272's Avatar
Beginner Wide Angle Question
Since DSLRs have a smaller sensor, can you achieve a 180 degree field of view with just any fisheye lenses? Thanks in advance!
07-11-2013, 02:09 AM - 1 Like   #2
carrrlangas's Avatar
On the contrary, smaller sensors need smaller focal lengths to achieve 180 DIAGONAL field of view. For example, the F17-28 zoom, designed for 24x36 film, goes from 180 at 17mm to 90 at 28 whereas the DA10-17 goes from 180 to 100 on APS-C sensors.
07-11-2013, 03:08 AM   #3
Na Horuk's Avatar
If you look at the lens review database:
Pentax Lenses - Pentax Lens Reviews & Lens Database
It usually lists the angle of view for FF and APS-C
07-11-2013, 05:06 AM   #4
Good Morning,
The simplistic answer is yes it does - across the diagonal of the lens (top corner to bottom corner). From there, you can ask plenty of questions and the answers become progressively more complex, because of how fisheye lenses are designed. Here is an older thread that addresses the entire topic.The reason for the complexity is how the optical engineer designs the lenses, and it all comes down to the type of projection that is used. You can get a sense of this by looking at a fisheye image, that has been defished, and see what the two images (the scene as a figheye and then its conversion to a standard view). This link does probably the best job at this that I have come across.hope that helps.
07-11-2013, 09:26 AM   #5
Nice! There's no shortage of info here.
07-12-2013, 12:48 AM   #6
kh1234567890's Avatar
And here : https://www.pentaxforums.com/forums/pentax-slr-lens-discussion/217537-how-do-...ml#post2302044
k-mount, pentax lens, slr lens
Question about Fisheye vs. Ultra-Wide Angle steezylistic Troubleshooting and Beginner Help 13 06-21-2013 03:17 PM
wide angle question murphyinc Pentax SLR Lens Discussion 14 02-28-2009 12:23 PM
Rectilinear vs fisheye wide angle question PentaxPoke Pentax SLR Lens Discussion 23 09-03-2008 10:45 PM
Wide angle question BARCUD Pentax SLR Lens Discussion 4 07-04-2008 01:34 PM
wide angle question axl Pentax SLR Lens Discussion 5 07-04-2007 02:50 AM
All times are GMT -7. The time now is 03:33 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
