Originally posted by tom1803
It does sound as if you have a problem with the aperture blades sticking.
You'll note that when you look through the lens, when not mounted to the camera and the aperture control ring is set to the "A" position, the blades are closed. When you mount the lens, the camera moves the aperture lever on the rear of the lens to open the blades. In your case, the blades are sticking and not opening fully, until you move the aperture ring around a few times, which loosens the blades. Unless you're willing to take the lens apart, you'll need to have it fixed by a repairer.
I'm not sure what the problem might be in regards to your issue with metering, but if you've already tried cleaning the contacts, then the problem will be internal. Perhaps the leaky oil that's causing the aperture blades to stick is also getting into the electrical contacts, causing problems.
Problem Solved. About to pack the lens off for servicing and one more look at the aperture blads and connections. It felt a little stiff where the camera operates the aperture. The arm was a little bent and up against the lens body. That would have been causing the aperture blades to stick and also throw out the metering as the rest of the esttings were changing but the apeture staying the same.
tried in all settings now and working fine.
I must have bumped it at one stage but cannot remeber where as I am vet careful with my gear.
John
