Originally posted by gazonk Thanks! I see you have the 16-45 - is the wider FoV of the 15 significant or just barely noticeable? I already have the 16-45 and have two conflicting wishes: (1) More wide angle, as much as possible, and (2) A lighter camera bag for everyday use with only a set of three limiteds (I have the 35 and 70 limiteds). I've considered the Sigma 10-20 but I am not convinced. I've also considered the DA12-24 but it's a bit bulky and expensive...
It's noticeable, but not significant. I'd say somewhere in between barely noticeable and significant. At 16mm I've never had to worry about my feet being in the photo. With the 15mm I had to stand with my feet farther back for just a couple photos. However if you're looking for something more wide, the 15 may not meet your needs here. It will for compact size, but the 12-24 might be a better fit if you want to go wider, although much bigger in size. I wouldn't consider the 10-20 a large lens, as it's much smaller than my FA* 24, but it's not small like the 15.
I used both the 16-45 and the 15 at the same time, and the 16-45 was always sharper. I also owned the DA 17-70, DA* 16-50, and DA 18-55 at the same time, and ended up selling all but the 16-45, but that's another story.
Here's an example below to compare with my example posted here earlier. This one is at 16mm, but I wasn't as close to my subject as I was in the other photo. However this may help you with how much background a 15mm takes in compared to 16mm:
