07-18-2013, 02:11 PM   #1
Question on FA77/DA70 focal lengths
Sorry for the dumb question, but hopefully this is quick to answer.
I see a lot of comparisons on the FA 77 vs. the DA 70, and I'm wondering about equivalent focal lengths. Since the FA is film format and the DA is APS-C format, don't they end up with different equivalent focal lengths? So:
- wouldn't the DA 70 be equivalent to 105 on a full frame, while the FA is 77 on a full frame?
- and is it true that the DA 70 cannot be used on full frame?
So when comparing lenses would one be looking at both of these for the same purpose? And yet I see a lot of head-to-head comparisons of these two. Or is that there's something about the physical focal lengths that makes them both highly regarded and naturally comparable; i.e.: why not compare DA 70 to FA 100?
Thanks for clarification.
07-18-2013, 02:15 PM   #2
Docrwm's Avatar
They are both adjusted on APS-C so the 70 is~105 and the 77 is ~115.5mm.
You want to read this In Depth review:
https://www.pentaxforums.com/reviews/da-70mm-vs-fa-77mm-limited-comparison/introduction.html
07-18-2013, 02:20 PM   #3
QuoteOriginally posted by Docrwm Quote
DA 70mm vs FA 77mm Limited - Comparison: Introduction - PentaxForums.com
Ah. For some reason I was thinking the DA lenses were labeled differently. Like I said, dumb question.
Thanks!
07-18-2013, 02:23 PM   #4
Docrwm's Avatar
QuoteOriginally posted by Takumar55 Quote
Thanks!
No dumb questions. That's a common one, but that means that there is a lot of confusion on it. The In-Depth comparison I linked to is a very good review. Enjoy.
07-18-2013, 03:01 PM   #5
Just to avoid any misunderstandings: The FA 77 was built for FF. It fills the frame fully and, with 77 real millimetres, is what you might call a portrait lens, with a 50% longer FL than a standard lens.
AFAIK the 70 is for APS-C only (that's why it is so small). I don't own one but I suspect that on FF the corners would be pretty dark (beyond recovery).
07-18-2013, 03:26 PM   #6
Docrwm's Avatar
QuoteOriginally posted by Pentaxosaurus Quote
I've mounted my 70 to my SF-1 and the image in the 100% FF viewfinder is fine. Of course only the emergence of an actual Pentax FF dSLR would make this a meaningful issue.
07-18-2013, 03:34 PM   #7
Pål Jensen's Avatar
The DA is a 70mm lens and the 77 a 77mm lens regardless of format. However, the 77 is designed to cover the 35mm format (FF) whereas the 70mm to cover APS. If you want to know these lenses focal lenghts are in 35mm format equivalents you multiply their focal lenghts with 1.5. Ie you need an 115,5mm lens on an FF camera to get same angle of view as the 77 on an APS camera.
comparisons, da, equivalent, fa, format, frame, k-mount, lengths, lot, pentax lens, question, slr lens
lens focal lengths pfannkuchen_gesicht Troubleshooting and Beginner Help 10 06-15-2013 02:38 PM
odd focal lengths Virginia Bill Pentax SLR Lens Discussion 68 06-26-2012 12:46 PM
Comparing 50mm focal lengths... Again. Mareket Pentax SLR Lens Discussion 8 05-08-2012 05:57 PM
FA limited focal lengths Anvh Pentax SLR Lens Discussion 36 04-17-2012 11:30 PM
Focal lengths and large format - Noob Questions David-C Pentax Medium Format 11 01-04-2012 07:10 PM
All times are GMT -7. The time now is 12:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
